Old 4th September 2010, 05:40 PM   #1
Default Lm3886 + irf540/irf940 (mosfet) ?
Hello all,
I have a few LM3886 and a very strong power supply.
I would like a few more Amp to be able to flow trough the output...
So I thought "what if I add some mosfet there?"
would that scheme work ?
Would another (similar) design work ?
what if I use a bipolar based design instead of mosfet ?
and would this thing would be able to deliver the 15A my regulator is able to supply ?
Sorry if those are very stupid questions...
Old 4th September 2010, 10:08 PM   #2
gootee is offline gootee  United States
Something similar should work. I didn't look at your circuit in detail but there are many similar "current booster" ideas that have been used successfully, especially with opamps in place of the chipamp.
There are some application notes with similar ideas and topologies, such as AN-272 at national.com and AN18 at linear.com. But none of the ones I saw used MOSFETS.
Maybe someone could try simulating something very similar in LTspice.
Old 4th September 2010, 10:46 PM   #3
star882 is offline star882  United States
star882's Avatar
That's a very poor way to drive MOSFETs. Use a proper gate drive circuit. And PMOS generally doesn't perform as well as NMOS, so most modern designs use all NMOS output stages.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 4th September 2010, 10:59 PM   #4
I've used this approach and it works well :
Old 5th September 2010, 12:09 AM   #5
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
Using a single forward biassed silicon diode in the drive circuit is an approach copied from a bipolar output circuit I'm guessing. These MOSFETs need around 4V gate bias, quite a bit more than the 0.7V that suits bipolars.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 5th September 2010, 12:15 AM   #6
I would think, too, that you'd want to find some way to also use the output current from the LM3886. Otherwise, you might as well just have a little opamp, there.
Old 5th September 2010, 12:28 AM   #7
theAnonymous1's Avatar
Or just use one of the LME498xx IC's from national designed to drive FETs and BJTs.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 5th September 2010, 12:30 AM   #8
But this one will be totally in class B. Which would give some crossover distortion.
See here some good bias circuit/alternative for the same concept.
http://electronicdesign.com/article/...class-ab-.aspx
With kind regards,
Bas
Old 5th September 2010, 12:54 AM   #9
jackinnj's Avatar
Originally Posted by theanonymous1 View Post
or just use one of the lme498xx ic's from national designed to drive fets and bjts.
lme49830
Old 5th September 2010, 01:05 AM   #10
Thanks a lot for all your advices,
you are very right that an opamp would work as well.
I tried to modify the design according to what you said and I have no clue if it would work or not.
I have also no clue about the right values for the resistors R6 to R8, nor how to calculate it.
50W mosfet amplifier IRF540/IRF9540 apexaudio Solid State 90 29th August 2011 10:53 AM
LM3886 discrete mosfet full 42V regulator Mach5 Chip Amps 25 17th February 2010 08:07 AM
IRF540 or IRF3710............................ mosfet1 Pass Labs 6 6th November 2009 10:57 PM
LM3886 driving mosfet pro Solid State 18 28th June 2009 11:21 AM
Irf540 ANTHONY2181 Swap Meet 0 15th August 2002 04:39 PM
Page generated in 0.09846 seconds (79.45% PHP - 20.55% MySQL) with 11 queries
