| Chip Amps Amplifiers based on integrated circuits |
Hey...
Okay, I wanna get a GC on the case... For 2 monobloks powered from one xformer, would this be okay: 120V 18V+18V @3.3A or should I go for a higher VA rating - I've read diff recomended values over this and just wanna make sure.... ![]() Next up, i/o. Is it possible to have a few inputs and possible and aux out - or would a preamp be more suitable? Ta Dan |
#2 |
Meta, I first powered my GCs with a single 120VA transformer and they sounded great. I would say that using one transformer per channel gives a bigger soundstage so you could either go for two 80VA transformers now or add a second 120VA transformer later.
Where are you buying from? The Antrims from Maplin are one of the best torroidal transformers available in the UK. You can build a preamp section to the GC, either in the same case of in a separate one. But what do you mean by an AUX out? If you mean output for some sort of recorder, then it should really be buffered. If you haven't already done so, see my GC FAQ page
The truth need not be veiled, for it veils itself from the eyes of the ignorant. |
#3 | |||
Hey Nuuk...
Great site! Thanks!! Quote:
88-2584 | 120VA 18V + 18V @ 3.33A Toroidal Xformer Quote:
The actual GC I was gonna will be based on the inverted one on ur site... The only other thing, is a headphone socket would be nice - simple to add? Quote:
Thanks... Dan |
#4 |
Hi Dan,
Have you got a link for Rapid? - I've never heard of them and would like a look at what they do. For the inverted GC I strongly recommend copying the attenuator design on my FAQ page. Apart from being designed specifically for the inverted GC, the signal will only pass through two resistors. A headphone output usually has it's own amplifier but you can take a feed from the output of the amp and adjust the volume using some resistors. This has been covered somewhere on these forums so try a search. A preamp section would consist of some phono sockets wired to a selector switch (rotary type using non-shorting contacts). That then feeds the volume control which passes the attenuated signal to the input section of the amp. Again refer to the Preamp page of Decibel Dungeon for all the 'how tos'
#5 |
Nukk, http://www.rapidelectronics.co.uk is the web addy for rapid...
Thanks again for all the infos - looks like with ur site and this forum I should be sorted ![]() Thanks again... Dan |
| How best to use the PSU xformer I have | Steerpike | Tubes / Valves | 1 | 12th November 2008 09:27 PM |
| Chipamp into xformer | StanJ | Chip Amps | 10 | 15th May 2008 07:09 AM |
| Raytheon xformer ID | redrabbit | Parts | 1 | 18th May 2006 06:33 AM |
| Think these are useful -- huge xformer?! | rif | Parts | 21 | 13th August 2004 10:00 PM |
| Help with Shorted Xformer | lgreen | Parts | 1 | 27th June 2004 04:58 PM |
| Page generated in 0.08905 seconds (74.91% PHP - 25.09% MySQL) with 10 queries |
