TDA7265 for multimedia speakers
Old 27th September 2010, 12:13 PM   #41
pra3718 is offline pra3718  India
Measure the voltage from pin 3 to 5. There should be more than 6 or better more than 7 V to switch the amplifiers completely on.
Thank you, Yes, I rectified that. Now it's sounding error free.
Old 28th September 2010, 12:28 PM   #42
I think, my searching is over. 7265 sounds very good. Sound quality is far better than 2030-2050 for me. With reference to post # 7, sangram is right. I am using local-made transformer 18-0-18 90VA which is not really 18v. My supplier said it is between 16-17V Assume 16*1.4 = 22VDC. I found it is perfect for 7265.
As I post before, I have fabricated pcbs in quantity. And I have excess in stock. If somebody require I can share it.
Further process is going on... I will post again.
Thank you Sangram, Pacificblue.
Best Regards.
Old 7th October 2010, 04:06 PM   #43
As I learn that when bridge tda7265 all protection disabled. I found MUTE is also not working, is it my fault or it's a disadvantage of bridge ?
Old 7th October 2010, 07:10 PM   #44
pacificblue is offline pacificblue  Germany
Did you use the bridge circuit from the datasheet?
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 8th October 2010, 09:21 AM   #45
Yes, but no zobel used for both stereo & bridge.
Old 8th October 2010, 06:42 PM   #46
Well, the same thing as before. You need to copy the mute/standby circuit of the typical application circuit and make sure that pin 5 is at least 6 or better 7 Volts below pin 3.
Old 9th November 2010, 12:59 PM   #47
TDA7265, is sounding good for me. Mute pin is working good. Yes, pin 5 is at least 6 or better 7 Volts below pin 3.
Is it possible that when no audio signal detected, mute pin 5's voltage should go below 6 volts. means amp should go in mute-mode. And when audio signal detected voltage should raise to minimum 6 Volts.
Old 25th September 2012, 03:08 AM   #48
ranjitraj is offline ranjitraj  India
Which has better sound quality TDA7265,TDA2050 and LM1875 ?
Old 25th September 2012, 11:49 AM   #49
@Ranjit : I read your earlier thread, I think you are little confuse for what to do.. Do you completed TDA7294 ? If yes it is good to TDAxxxx series. I don't know your electronics knowledge but if you want to build something better which you can live long with... then switch to LMxxxx series minimum 30-40watts.
Please ignore above paragraph if you just want to know better sound quality TDA7265, TDA2050 and LM1875... then answer is LM1875. (its my opinion) Some of branded music system and television have used TDA7265.
I know how to tame TDA7265, TDA2050 and LM1875.. choice is yours.... I have used dozens of tda7265. With tda7265 you can build like commercial amp but should not expect more for just 25watts -- 4R Load
Old 28th September 2012, 05:15 AM   #50
Hi Pra3718,
Thanks for reply. I have completed tda7294 amp , it is sounding good but very low i think it is because of i am powering it with 12-0-12 trafo.
I asked the question because i tested tda2030 ,tda2050 and lm1875 (no mute and standby) but i never tested tda7265 and it has mute and standby pin.
TDA7265 for multimedia speakersHide this!Advertise here!
Tda7265 thetube0a3 Chip Amps 26 10th August 2012 12:34 AM
TDA7265 Humming sexya Chip Amps 6 10th February 2010 09:49 AM
Tda7265 + tda7439 sexya Chip Amps 9 24th October 2009 02:49 PM
Powered Multimedia Speakers with DSP bimbla Chip Amps 1 18th January 2006 01:35 PM
multimedia powered speakers... driver match? trespasser_guy Multi-Way 0 16th May 2003 05:38 PM
