Old 1st September 2010, 06:34 AM   #1
volx is offline volx  South Korea
Default LME49830 dose not work any body help!
LME49830,2sk1530,2sj201 used.
- Condition -
Mute pin - Gnd
input - Gnd
Power - +-25V
- Problem -
Very high current.
Supply Voltage drop
Dose not adjust BIAS (5V fixed) - AN-1850.pdf, FIGUER 3, J9 connect voltage
Check the wiring was 4-5 times. No problems found.
i need help!
Old 1st September 2010, 11:51 AM   #2
I like the heatsink and clip on the chip.
Can you give a reference to the pairing?
I do not like all that uninsulated wiring.
regards Andrew T.
Old 1st September 2010, 01:13 PM   #3
First, seek understanding.
My English is very bad.
"Reference to the pairing" What do you mean?
Say easily explained.
Anxiety seems to be wiring.
However, there is no short circuit.
0.8mm tinned wire is used.
First, as I know, gives more information.
MOSFET pair 4 was used.
Is now checking all the MOSFET.
Thanks for your reply.
Old 1st September 2010, 04:30 PM   #4
monkey29's Avatar
First, check whether there is short-circuit in MOSFET.
Before power on , Rp1 (200R) should be adjusted to the maximum resistance.
More importantly, the MOS transistor and temperature compensation transistor should be installed in the same heat sink above. And to place insulation film.
Old 1st September 2010, 04:39 PM   #5
monkey29's Avatar
“AN-1850.pdf, FIGUER 3, J9 connect voltage”
J9 should be test points. Can not connect voltage.
Old 1st September 2010, 05:25 PM   #6
hyfeng is offline hyfeng  China
Old 1st September 2010, 05:28 PM   #7
maybe mute pin connect like that?
Old 1st September 2010, 06:45 PM   #8
Just measured. The wrong word. the right connector.
Old 1st September 2010, 06:54 PM   #9
Thanks for reply
Problems found
Wrong resistance. 1.1K to 11K was changed to.
LME49830 pin 12 on the resistance
However, there is oscillation. Both high frequency and low frequency
MOSFET heatsink is very hot.
Please advise.
Old 3rd September 2010, 10:47 PM   #10
panson_hk's Avatar
can you find out the oscillation freq (high and low)?
Dose a Capacitor have to be pre charged every time? boogeronmyfinge Power Supplies 7 24th December 2008 08:52 AM
Dose any one has experince about the implementation DSP in DAC, like Theta Did? lanyuflying Digital Source 2 20th January 2008 12:12 PM
micromega T dac dose any body know how to upgrade the sound quality NAP 160 Parts 1 28th July 2002 03:02 AM
Page generated in 0.09660 seconds (79.43% PHP - 20.57% MySQL) with 11 queries
