ATX PS Gainclone?
ATX PS Gainclone?
Old 28th November 2004, 09:25 PM   #21
mateo88 is offline mateo88  United States
It really isn't very difficult to fit an amp and power supply into an ATX case. I've done it a few times, and though it is a bit tight, the amp fits nicely. Be sure to use a fan, though, because things will get a bit toasty without any airflow.
Old 28th November 2004, 10:45 PM   #22
ir is offline ir  New Zealand
Send a message via ICQ to ir
i should point out that it wasn't my mod
fitting it in isn't an issue at all, but running it from the supply itself can be
ah yes, the exploding caps - but to be fair that one cap was an oversight. wasn't needed anyway
amp works very nicely
heatsink is VERY undersized but PSU is fan cooled anyway so it really doesn't matter, that said it does get mighty toasty. but it ain't broke and so it ain't gonna be fixed
Old 29th November 2004, 12:12 AM   #23
jackinnj is offline jackinnj  United States
jackinnj's Avatar
ATX PS Gainclone?
American Army Motto:
"Fix it until it's broke"
Old 2nd December 2004, 08:05 PM   #24
MS275 is offline MS275  Canada
Since few months I'm using 3 old computer power supply to feed a 12V amplifier (rated 225W). I use the 12V outputs in parallel to get around 30amps at 12V (amp can pull 40amps max).
I use diodes on each output.
When I use the amplifier near to it's limit, PS voltage is dropping to 9V, it's not a stable 12V. Also diodes drop voltage a bit.
I think it is the cheapest way to get 30amps at 12V and until now it is reliable.
36V in serial can be done too.
ATX PS Gainclone?Hide this!Advertise here!
Freebird + Gainclone = "integrated" gainclone? bikehorn Chip Amps 9 5th January 2006 04:07 PM
JLH v Gainclone? Jezz-the-Fezz Solid State 5 12th December 2005 01:08 PM
Big gainclone steven344 Chip Amps 10 23rd November 2005 08:58 PM
