| Chip Amps Amplifiers based on integrated circuits |
OK So i tossed together an amp from chipamp.com
I'm using this with an Advent 300 receiver as its preamp and pretty much ran into something I can't make up my mind on. I used the Ci cap as per the LM3886 datasheet because I prefer low DC offset. I've done this on my previous LM3886 amps as well after trying them without. The Advent 300 receiver has coupling caps on the outputs of the preamp so I'm thinking I don't really need input caps on the chipamps. But then I start thinking what if one day I just wanna drive the amp from an ipod or something. Being I have the Ci cap shouldn't I be fine regardless as long as there isn't some retarded amount of DC on the input? I have a pair of 10uF film caps I can use, but it will look much cleaner without them. |
#2 |
I agree the design choice to use a DC blocker between the Source and the Power Amplifier.
You do not need two, series connected DC blockers. One is sufficient, cheaper, uses less space, and gives less deterioration of the Audio Signal. You can choose to bypass the Source output DC blocker or to bypass the receiver input DC blocker. If both Source and Receiver have a second pair of output sockets, the second pair can be DC coupled and clearly labeled. You can now experiment to hear if there is any difference between the sound quality by using one or other DC blocker. Then if you ever attach unknown equipment you have the safe option (the AC coupled socket) or the DC coupled socket.
regards Andrew T. |
#3 |
Just fired it up for the first time. Semi dissapointed.
I used a 20+20 300VA transformer as I'm mainly going to be driving a 4 ohm load. Amp tested 54W x 2 into 4 ohms. 30W x 2 into 8 ohms. I'm seeing around 26V+- give or take on my supply rails. Kinda thinking I should've bought the 22+22 transformer like I originally planned :\ |
#4 |
Is 54Watts not loud enough for you?
What is the sensitivity of your speakers? Only real way to get more wattage (around 100W) into 4ohms is to parallel two chips per channel. and up the voltage to +-35V dc (25V ac transformer). |
#5 |
tangmonster : 54 watts is actually more then enough. I think what annoys me is I planned to run the chips at a certain voltage, and planned my heatsinks accordingly.
Allwell. It certainly runs cool which is a bonus ![]() P.S. My last LM3886 project was a BPA-200 with servos. It does 219W into 8 ohms on the bench. |
| cap coupled output combined with cap coupled input? | nightanole | Analog Line Level | 9 | 24th July 2010 08:34 PM |
| Input cap? | CJ900RR | Chip Amps | 13 | 25th March 2006 11:54 AM |
| I'm an input cap! | Pano | Class D | 14 | 19th November 2005 10:56 AM |
| Input Cap | kinser | Chip Amps | 4 | 20th October 2005 03:24 PM |
| Resistor-Input vs. Choke-Input vs. Cap.Multip. | Blitz | Pass Labs | 13 | 26th September 2003 04:59 AM |
| Page generated in 0.07339 seconds (74.89% PHP - 25.11% MySQL) with 10 queries |
