tda2822m problems...
Old 20th August 2010, 02:16 AM   #1
pat allen is offline pat allen  Canada
pat allen's Avatar
Default tda2822m problems...
Hi group, i would like some inputs about this:
i try to use their(ST) suggested bridged test circuit on a TDA2822m and i get very poor performance. It doesnt play bridged at all, one channel is barely getting anything out of it...if i ask the circuit to play a bit more it start to pop pop pop, and eventualy stop to work, i need to unpower it all.
There is no DC at the input, i have a 10uf decoupling cap (along with the 10k input resistor to gnd).
When i look at it it feels to me like a connection is missing, or a feedback from amp #1 to amp #2...
Each channels play OK in mono mode so it is not toasted.
This is meant to power up a white noise self unit for sleeping aid (dont ask further).
I got a bag of them for free and i thought i could use one in this project,
thanks for any inputs.
Electronic engineer for automotive market.
Old 20th August 2010, 02:57 AM   #2
pat allen's Avatar
i found this variation of the bridged circuit...
(i dont know if the image will show up)
Old 22nd August 2010, 06:40 PM   #3
pacificblue is offline pacificblue  Germany
The feedback should come through C1, which forms a voltage divider with C2. You should check C1, if you don't get any feedback on pin 5.
The amp in post #1 is AC coupled, the amp in post #2 is DC coupled. Depends on the value of the speakers, whether you want to try #2.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 29th June 2013, 09:17 PM   #4
malti is offline malti
The circuit as shown on the data sheet does not work.
for mono bridge output:
You must put 100 uf on the output pins 1 &3 an connect them to the speaker for bridge output.
from pin 8 to pin 5 you should put a 10uf, +ve side on oin 8
from pin 5, 10uf to gound.
Pin 6 to ground
Input from pin 7
If you do not put the RC filter on the speakers, the cicuit will surely oscillate !
Old 26th July 2013, 01:53 AM   #5
cT equals piD is offline cT equals piD  United States
Pin 6 to ground
Input from pin 7
The bridge configuration according to the ST data sheets (schematic of post #1) worked fine for me, assembled on a socket board and 4.5VDC power supply.
How critical is the resistance value of the RC filter? I don't have 4.7 Ohm on hand, and I'd rather not parallel two 10 Ohm resistors that I do have on hand. Would 10 Ohm resistor in series with 0.1 microfarad cap be acceptable for the RC filter?
-Pete
Old 26th July 2013, 10:47 PM   #6
PetruV is offline PetruV  Romania
yes it should work with 1-10 ohms
Just a kid who likes building and modding things.No inspirational quote here for you
Old 27th July 2013, 01:40 AM   #7
Thank you! Of course I'd like to understand at least somewhat what is involved in designing such filters if you would care to explain.
-Pete
Old 27th July 2013, 03:01 PM   #8
johnr66 is offline johnr66  United States
-Pete
Without getting into a long explanation, the series RC network connected to the output of the amplifier aids in HF stability. The engineer who designed or tested the circuit chose the values that kept the amplifier stable with various loads that may be connected since he doesn't know the characteristics of the load customer will actually use. It is best to stay with the datasheet recommendation but you can certainly adjust the values for your use as long as stability is not lost.
Many of the new low power ICs have been designed to remain stable without the RC circuit on the output. Lots of the car stereo BTL chips have done away with them.
tda2822m problems...Hide this!Advertise here!
TDA2822M amplifier circuit questions junkmail Chip Amps 7 27th December 2014 09:01 AM
IE 8 problems lgreen Forum Problems 8 14th August 2010 10:10 PM
MiniWatt N3 problems, oscillation thumping and RF/motor problems. Destroyer OS Tubes / Valves 18 6th July 2010 01:14 AM
Problems Markz66mustang Car Audio 14 28th December 2004 07:04 AM
Copyright ©1999-2017 diyAudio
