Old 19th August 2010, 11:44 AM   #1
laki101 is offline laki101  Serbia
Default small microphone amp
I need a small, light ,cheap, battery powered microphone (computer like) amp
i need it for my rowing boat so that the rudder man can give orders without shouting as loud as he can
so it would be a computer mic or similar that goes into the amp circuit and than it goes into 2 or 3 (we will see depending on how good everyone can hear ) and it needs two be powered of a 9v battery or a 6v/12v small 2/3 Ah battery
any schematic or idea how to modify one would be great
Old 19th August 2010, 03:07 PM   #2
Goes into what? Horn speakers ? Headphones ?
How long does it have to last ?
Switching amp is most efficient.
Old 19th August 2010, 03:10 PM   #3
tangmonster's Avatar
randomly googled:
this one looks really simple:
Simple Microphone Preamplifier
try it.
you will need to amplify it afterwards using an amplifier.
If you want to go simple , i would look for a cheap car amplifier. and run both circuits of 12V.
Old 19th August 2010, 03:41 PM   #4
That looks very simple. I would suggest some form of clipping, to keep volume constant,
and help prevent feedback. Some diodes on the output would work.
Love those hand drawn diags...
http://zekfrivolous.com/sub/mikeamp.gif
Old 20th August 2010, 10:35 AM   #5
goes into 6 ohm (3x4 ohm 2 in line and one parallel which gives me the 6 ohms)
and it has to last on a 2,4 Ah 12v battery about 5 hours minimum and more would be great
i was thinking of making the preamp that tangmonster gave and than conecting it to some tda chip
would that work?
Old 20th August 2010, 01:26 PM   #6
Should work. Probably some chip will do all. Remember, horn speakers require
less than 1/10 th the power for the same volume.
Old 20th August 2010, 01:33 PM   #7
Ron E is offline Ron E  United States
Ron E's Avatar
would that work?
Do a search for diy megaphone or bullhorn, as that is what you are really after - you might get some more (if not necessarily better) ideas. I think you can get battery powered megaphones/bullhorns pretty cheap, perhaps cheaper than building one.
http://www.amazon.com/Pyle-Pro-PMP30.../ref=pd_cp_e_2
definitely cheaper than building one.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Small speakers for a small tube amp jeppix Full Range 17 29th January 2010 08:10 AM
Connecting Mixer,Laptop & Microphone lucknowm Digital Source 2 22nd September 2006 02:57 PM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
Need microphone amp borges Analogue Source 0 1st June 2005 10:52 AM
Microphone amp? zmoz Solid State 3 19th June 2003 11:09 PM
Page generated in 0.09023 seconds (72.47% PHP - 27.53% MySQL) with 10 queries
