| Chip Amps Amplifiers based on integrated circuits |
I just finished a simple modified CMoy for my motorcycle. It plugs into my bike stereo's aux in. It is powered by my cigarette lighter circuit, which is switched with the ignition. Given this application, I didn't include a power switch or a volume pot since the volume could be controlled both at the input device (my mp3 player or GPS) or at the stereo and the power turns off when I turn the bike off. It worked great on my office desk. Then I connected power from the plug on my bike. No music at all, just a soft hum. When I connect a 9-volt battery to it, the sound is great again. I have verified that I have 12.4V at the plug from the motorcyle to the amp. I have also verified the polarity. I mounted the CMoy in a plastic enclosure to make sure I don't have a grounding issue. Any other thoughts?
Additionally, I used this same power plug on my bike to power an amp purchased from BioScienceGeek on Ebay. That worked just fine. I'm not sure it's relavent, but I'm using an OPA2227 amp chip, the amp has a gain of 11, 220uf electrolytic power caps, .1uf poly input caps. I'm certainly no audiophile or electrical engineer, though I don't have trouble following electrical schematics. Thanks in advance for any help or advice. |
#2 |
The DC from your cigarette lighter may be fluctuating too much. Try extra capacitance.
Or an LC filter might be better in this case. |
#3 |
I'm leaving tomorrow for a trip and would like to use it. If I was going to add capacitance, can I just throw in a single electrolytic on the +12V input to the CMoy? Can you recommend how much capacitance?
I appreciate the help. |
#4 |
You can refer to what your BioScienceGeek amp used for its power supply.
#5 |
I tried a 1000uf cap, similar to the one in the BSG amp and still no sound at all. I go back to the 9V battery (no 1000uf cap) and it sounds great again. Do you have any other thoughts?
#6 |
Doesn't that CMOY design use some kind of rail splitting for the power supply?
If that is the case, you are shorting out the negative rail of the CMOY when you connect it to the bikes 12V power and the bikes audio ground.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#7 |
#8 |
I think you need to completely isolate the entire CMOY circuit with DC blocking caps. Input, output, and one between the feedback resistor and ground.
#9 |
Wait... the amp is connected to the input of a stereo?
X3 @ three posts above, but why would you want an amp between your source and another amp? |
#10 |
The output of the mp3 player is too weak (or the amplification of the stereo from the aux input is too weak). I connect an mp3 player or my GPS to the aux input to my stereo, then have to turn the stereo all the way up to hear it at 55mph. At 80mph, I can't hear much at all.
| Capacitor on Opamp Power Pins in Gwado CMoy | Skazi | Headphone Systems | 3 | 6th February 2010 02:07 PM |
| Modifying CMOY to cope with switching power | mattkosem | Chip Amps | 16 | 7th September 2008 10:26 PM |
| Cmoy power supply simple question | wiredmonkey | Chip Amps | 2 | 17th July 2007 12:44 AM |
| question about output power of CMOY | georgiano | Chip Amps | 4 | 23rd April 2007 08:44 PM |
| JADIS ORCHESTRA IN PCB (original is hardwire) | ANALOG GUY | Tubes / Valves | 2 | 2nd January 2007 03:25 AM |
| Page generated in 0.09773 seconds (79.57% PHP - 20.43% MySQL) with 10 queries |
