| Chip Amps Amplifiers based on integrated circuits |
Just for goobs like me. A link to simplyfy life. Looks like a good place to start-if anyone sees a problem please correct me.
Avel Y236651 250VA 18V+18V Toroidal Transformer | Parts-Express.com Last edited by rmcelroy; 11th August 2010 at 07:51 PM. |
#2 |
Are you going to run a 4 ohm load?
That one is fine for a 4ohm load even on the safe side. For an 8 ohm load you can go with higher voltage one like 25v+25V ac |
#3 |
Thanks Tang-I do have 8ohm horns.
Trying to learn here. Regie |
#4 |
#5 |
I would then go for the 250VA 25 + 25V transformer to get +-35V DC
If you horn is VERY efficient then the +-35V dc might be overkill but it can't do any damage except if your heat sink is too small. But if you ever want to use this amplifier on 4ohm loads you need to use the 18 + 18V ac transformer. |
#6 |
When you mix and match, don't forget about using two transformers to
add voltages. Two 18 + 18 can form a 36 + 36 system. Series arrangement. You can also parallel transformers, but check to see if the voltages are in fact identical. |
| Tranformer size how much is too much? | Soulwind | Power Supplies | 5 | 23rd June 2010 09:33 AM |
| Step down tranformer | jkeny | Everything Else | 2 | 18th October 2005 12:14 AM |
| Tranformer question | CPX | Parts | 3 | 7th February 2005 07:44 PM |
| Can someone explain this tranformer? | dvdwmth | Chip Amps | 5 | 9th September 2004 08:03 AM |
| Single Tranformer for ZenV2 | Shoog | Solid State | 0 | 19th November 2002 06:49 PM |
| Page generated in 0.07921 seconds (76.57% PHP - 23.43% MySQL) with 10 queries |
