Hum through speakers using GC & Laptop - Page 2 - diyAudio
Old 9th August 2010, 06:30 PM   #11
the weight of evidence is against me.
I wonder what I have seen in the past. They all looked like two core mains flexible.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 9th August 2010, 08:35 PM   #12
AndrewT, I have seen many older laptops with 2 wire (isolated) power supplies. We use them exclusively at work. That said, I've also worked on laptops that friends own that are 3 wire power supplies.
Tyler
Old 10th August 2010, 03:42 AM   #13
gootee is offline gootee  United States
Originally Posted by zebra100 View Post
It is a three pin PSU. So what can I do about the hum, aside from removing the ground (which I really don't want to do)?
Gfiandy and abraxalito both gave you other suggestions. Have you tried them?
Old 10th August 2010, 12:31 PM   #14
Have you tried muting everything in the sound card settings? If hum goes away unmute one at a time. I have seen this issue if you have a built in mic.
My adventure: http://www.1414audio.com/
Old 10th August 2010, 03:08 PM   #15
tangmonster's Avatar
I also thought laptops only had a 2 prong connector. then i went to look at one.
Most laptops i have seen use the "for EU plug" in this image.
Nobody has the correct adaptor so basically nobody uses earth on them.
The only time i ever found a problem with buzzing noise on the headphone out was when the laptop went into sleep mode while power supply was plugged in.
three options i see:
1) Disconnect earth and make the problem go away A short on laptop side will propably put the powersupply in safety switch off mode. You are using a dc blocker cap on your amp input?
2) if a friends charger solves the problem get a different charger
3) Only connect amp with power supply plugged out
Old 10th August 2010, 03:49 PM   #16
to fit a UK socket outlet (to match a BS1363 plug top) one must open the protective shutters over the Live and Neutral receptacles.
This is done with the third prong of the plug top. But that third prong does not need to conduct, it can be all insulating.
The clue is in the cable. Is it a flattish oval with two cores, or a round cable with three cores?
Pics of the cables would be more informative, than pics of the plug tops.
regards Andrew T.
Old 10th August 2010, 07:27 PM   #17
Yes, sorry should have said. The input ground is connected to the star earth, and I have tried a ground lift in the past, athough I have taken it out.
I think it could just be that the amp doesn't agree with SMPSU's.
Chris.
Old 10th August 2010, 07:32 PM   #18
I think I may have to try something radical such as a USB D/A converter (like this one Behringer UCA202 U-Control USB Audio Interface (GAK)) for use with the laptop.
Chris.
Old 10th August 2010, 09:15 PM   #19
Send a message via Yahoo to Th3 uN1Qu3
Not much. Removing the ground shouldn't have any adverse effects, it's not a computer with exposed metal parts. Anyway, if you haven't tried yet, run the laptop on battery to confirm that the problem is within the laptop PSU.
If removing the ground doesn't work either, most likely the main filter capacitor inside the laptop's power supply has dried and needs replacement.
"Audio grade" components simply means that they failed at a more critical job.
Old 22nd August 2011, 01:53 AM   #20
Buying a USB DAC won't work as they are grounded through the laptop USB port anyway (unless you hooked it up via an optical out on the laptop but it shouldn't be this difficult surely). I'm not quite sure what the deal is with laptop power supplies as I have the same problem on my 2 DIY amps but not with my comercial (Yamaha) amp and only with a laptop that has a grounded power supply. Ones with no ground work fine.
How to removing the ******* HUM sound from our GC?? thomgun_lc Chip Amps 64 13th June 2008 08:20 PM
3875 GC Hum Crash&Burn Chip Amps 5 7th September 2005 10:12 PM
Amp needed for measuring speakers with laptop JohanH Multi-Way 7 24th February 2005 06:28 PM
Help!!! GC hum when input attached HawkeyeStoob Chip Amps 6 6th December 2004 08:29 AM
Copyright ©1999-2017 diyAudio
