Small chip amp for satelite speakers. Small chip amp for satelite speakers. - diyAudio
Old 5th August 2010, 05:24 AM   #1
Dynsdale is offline Dynsdale  South Africa
Default Small chip amp for satelite speakers.
Hi All.
I'm toying with the idea of using small active satelite surround speakers for a 7.1 system.
I won't be needing alot of power for these and am asking if anyone can suggest a high quality amp chip that would suit this purpose.
The reason I'm considering active speakers is that I want to mount them on my cieling and run the wires through the roof space using balanced audio for noise reasons.
I have looked at a good few datasheets for the popular 'LM' and 'TDA' types.
Maybe someone with more expierience with chip amps than me can help.
Cheers!
Old 5th August 2010, 05:42 AM   #2
vijay_meyou is offline vijay_meyou  India
If you really looking for low power you can use TDA 2030 14-18 watts Rms small chip amp. simple construction only few componets.low operating voltage 12-18 v sufficient.
just search over DIY
vijay
Old 5th August 2010, 06:24 AM   #3
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
So you're running mains into your roof space too? Might be wise to double check for safety (fire risk) if you take that approach. Myself, I'd run lowish voltage DC and balanced amps (meaning bridged) to avoid any grounding probs. Agree that TDA2030 is an excellent and affordable choice.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 5th August 2010, 10:08 AM   #4
Hi all. Cheers for that, I was favouring the 2030 on the investigations I have done prior to approaching this forum.
It did look good on paper, happy for a bit of confirmation.
I have only experimented with the balanced line RX/TX side of the project so far. I have not delved deeply into the realms of the chip amp.
As far as the mains through the roof goes, I have given the legalities a thought and am yet to approach the relevant authorities with my inquiries.
If that is not allowed I will have to change my strategy a little. I love cables that are hidden away!
Thanks for the info.
Cheers!
Old 5th August 2010, 08:13 PM   #5
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
Unless you have a real desire to do this for interest reasons. I would just run speaker cable to the speakers and have wall boxes to plug an amplifier into. This way there are no leagal problems, if the amp goes wrong you can easily change it and there is much less chance of a fire in your roof space. With small speaker near the ceiling speakers and a reasonable quality speaker cable there is unlikley to be an significant difference in sound quality.
You can then experiment with your amplifer design without the need to get into the roof and upgrade if you want to.
Andrew
Old 6th August 2010, 07:04 AM   #6
Hi Andrew. Yes it is for interest reasons and I was trying to ovoid long speaker cable runs.
As far as mains in the roof goes, its not a good idea after a bit of rational thought.
I am starting an experiment with balanced line driven active speakers and their feasability for surround sound. Purely objective, if it will be too much PT I'll happily scrap it and do something more conventional as you suggest.
Define "reasonable quality speaker cable". (Just kidding there, bit of mischief on my part :P)
Thanks for the info, it's good to get many angles on this subject.
Cheers!
Carl
Old 7th August 2010, 11:38 AM   #7
gfiandy's Avatar
I shall stand a long way back from the what is reasonable quality cable question I believe that flame war has been raging for many years now.
If you are really interested in creating a good low to medium power active speaker solution. I would look at the LM1875 rather than the TDA2030 its specifications are slightly better but it actually sounds much better. To avoid the leagal problems you could run transformed power to the speakers at 24V AC or lower which I think is the highest voltage you can use without needing to use high voltage protection techniques.
However bear in mind if the amp goes unstable they can flame out, and 24 V AC is quite capable of heating a cable to flash point with enough current or causing sparking. If you are putting it in a roof space put it in a metal enclosure and consider any risks from the cable potentially sparking.
For an active solution, you can get a very significant improvement in sound quality by going to full active and using one amplifer for each drive unit. Use a low level crossover before the amplifers, this way it is easy to create a 4th order L-R crossover and any frequency response shaping you require with low cost small components.
Andy
Old 11th August 2010, 10:31 AM   #8
Default Chip amp
Hi Andy, thanks for the heads up on the LM1875.
Running 24 Ac through the roof sounds good, it will have the added advantage of not having to contain the PSU transformer in the housing, thus keeping it small and elegant. My wife would not be keen on obtrusive speakers ruining the decor.
Carl
Small chip amp for satelite speakers.Hide this!Advertise here!
reccomend small chip amp for unusual job. neutron7 Chip Amps 15 15th January 2012 10:14 PM
Small speakers for a small tube amp jeppix Full Range 17 29th January 2010 08:10 AM
Small chip amp driven sub-woofer hybridfiat Subwoofers 0 12th September 2008 03:42 PM
Best chip Amp for small Computer speakers? Ricren Chip Amps 6 16th July 2006 06:55 AM
PC-speakers + small amp (key words: small, cheap) rho Multi-Way 8 18th May 2006 01:19 PM
Copyright ©1999-2017 diyAudio
