| Chip Amps Amplifiers based on integrated circuits |
An amp built with a pair of LM4780 Chips would give more power , ( and, avoid grounding problems ? ) It contains two LM3886 chips on the same
" block " in parallel . Would two " bridged " LM3886s on each side be more desireable ?? David V. Webber |
#2 |
depends on your load and wattage needs whether you want bridged or parallel (or both)
more singles make heatsinking easier since the heat sources are distributed |
#3 |
This amp , ( when built , ) is for my " Bedroom Speakers " ) . They are
two - ways . JBL LE14A and JBL LE85 Mid / High . [ Might add a pair of JBL Slot Radiators , but don't own them . ] 8 Ohms . They are quite efficient , with massive magnets and voice - coils . An actual 20 Watts is usually OK for me , but too loud for most of my family ! However , there are always the people who want to " borrow " a GOOD amp for their slide - show or party , and I don't know what their needs might be ! David V. Webber |
#4 |
if your friends have 4 ohm speakers and you bridge the lm4780 or bridge two lm3886's they won't be able to cope.
For a safe bet i would rather parallel them with +-35V rails. For your 8ohm loads it is overkill and they will play at 50W all day long and for 4 ohm load you will easily get 100W. |
#5 |
if you want it to be stable into 4 ohm load with 2 lm3886's in parallel.
I would use a 400VA 25 0 25 ( 2 x 200VA 25 0 25 for dual mono) 2 x lm3886 per channel in parallel I would use 30000uF per voltage rail ( or 20000uF per rail for dual mono) |
#6 |
I don't know how frequent 4 Ohm speakers are . What if I just did not
lend my amp out to folks with those ? [ A " Lend " situation might happen only once or twice a year , if ever . ] For my own , pair of 8 Ohm JBLs , what would be the best choice ? A LM4780 for each channel or a pair of LM3886s on each side ? David V. Webber |
#7 |
A single chipamp driving a single 8ohm speaker is best advice for a newcomer.
regards Andrew T. |
#8 |
#9 |
Ok . That is probably wise . But , in case I later " upgrade " I may buy the 300 VA
Plitrons and a pair of the MUR860 Bridges ; ( or , for the added pair of chips would one have to have FOUR bridges ? ) [ I've seen photos in galeries with single - channel bridges with EIGHT diodes !! ] While I am certainly a " newcomer " to Chip - Amps , I am not a newcomer to electronics . Way back in the day , I built a Heathkit AR - 15 , with all the resistors having their gold bands either top or right . ( I know , very anal . ) I set - up the Quality Control Laboratory for a well - known Carbon and Metal Film Resistor company . I was supervisor of a small assembly - line for Vishay , before their production left this area . I have built four - pair of speaker crossovers , for fine DIY Speakers ; [ one custom designed just for me by Greg Timbers , the head JBL XOVER guy ! ] ( These are just composed of Coils / Caps / Resistors . ) I was head of Final QC for a large , New Jersey Electronics firm , which made the communication gear for Philadelphia and NYC trains ; ( a lot of automated surface - mount boards . ) I make BEAUTIFUL solder joints ! David V. Webber |
#10 |
Read through these pages about power supplies. Study the various methods. The 8 diodes you saw was probably one of the versions with 2 bridge rectifiers (the method I prefer)
Solid State Power Amplifier Supply Part 1 A 300 VA philtron will be overkill for 1 chip per channel and will probably be good enough for 2 chips per channel. A 400va will be great for 2 chips per channel into 4 ohm loads or 2 chips per channel bridged for 8 ohm load. You cannot connect a bridged channel to 4ohm load. If you want to use a single chip on 4ohm loads or bridged chips on 8 ohm load you need to use a 20Vac transformer not 25Vac if you want to use dual rectifiers (8 diodes) you need to make sure you get a 25 0 0 25Vac or 20 0 0 20Vac transformer and not just a center tap (25 0 25Vac or 20 0 20Vac) one. |
| how to wire Dual Mono chip amp Kit | merickrc | Chip Amps | 11 | 22nd March 2009 05:39 PM |
| Chip Amp General Question | bluetech | Chip Amps | 18 | 16th January 2009 10:38 PM |
| Chip amp Newbie Question?? | richyrich212t | Chip Amps | 2 | 17th December 2006 04:04 PM |
| Chip Amp PSU Question | Lyerigolfin | Chip Amps | 8 | 16th June 2005 09:10 PM |
| Very basic chip amp question | leadbelly | Chip Amps | 3 | 13th August 2003 04:25 PM |
| Page generated in 0.10758 seconds (82.44% PHP - 17.56% MySQL) with 10 queries |
