How do you hook up an radio shack electret mic?
Old 2nd August 2010, 02:19 PM   #1
DemonicCrow is offline DemonicCrow
Default How do you hook up an radio shack electret mic?
I have built a headphone amp using the LM386 chip and it works perfect (in attachment). Now I'm wondering how I would add the electret microphone to it with minimal parts I hope.
Electret Microphone Element with Leads - RadioShack.com
Sorry I am new with audio.
Old 2nd August 2010, 02:47 PM   #2
UncleArt is offline UncleArt  United States
That mic element needs a power source. A battery/batteries will work fine.
You put the power in on the red lead, if I recall, and the signal comes out on the shielded white lead.
"Shield" is common negative for the signal and the power source.
Your headphone amp may not have enough gain; Radio Shack doesn't list the output level of that element, but that and a wiring diagram should be on the back of the little card it comes in.
regards
art
Old 2nd August 2010, 07:08 PM   #3
You can barely see whats on the back side. It show red wire being power, white is signal and silver being ground. look like there is a resistor going from power to battery and capacitor on the signal line. Does that even sound right though?
Old 3rd August 2010, 06:14 AM   #4
Mooly's Avatar
Most mic inserts are two wire, the case which is ground and signal ground and the "main" terminal which is both power and signal output. Usually use a resistor of around 2200 ohms to power the mic and take the signal via a cap from the main terminal.
If yours is different then I would do as you suggest... coupling cap on output wire, and a resistor to supply. Try 2200 or thereabouts to begin with.
Edit found this,
http://www.intricontibbetts.com/pdf/1070895974.pdf
Old 3rd August 2010, 02:55 PM   #5
Wouldn't I need an audio pot? I was wondering if I can use a 500k one cause I can salvage it from an old columbia stereophonic high fidelity. If I can do I need any special resistor or just connect it straight to my amp chip and mic?
How do you hook up an radio shack electret mic?Hide this!Advertise here!
panasonic electret mic amplification question internecine Everything Else 4 24th October 2007 05:08 PM
electret Mic preamp teopoz Chip Amps 10 14th October 2007 09:19 AM
directional electret mic recommendations? travis Instruments and Amps 9 28th September 2007 09:22 PM
Mesurement electret mic problems Bazukaz Parts 1 27th August 2006 03:13 PM
LM317 As Electret Mic Amplifier mrfeedback Solid State 14 25th May 2003 05:43 PM
Copyright ©1999-2017 diyAudio
