Old 29th July 2010, 03:48 PM   #1
Default ChipAmps.Com 3886 Kit :
What is the height of the assembled amp - kit , including normal room underneath for wires . I want to be sure it will fit in the HAFLER SE120
case I want to use ! TIA David V. Webber
Old 29th July 2010, 05:06 PM   #2
Basically you have the height of the LM3886 itself unless you go with taller capacitors. The height of the LM3886TF, which is slightly taller than the LM3886T, is shown as 1.052" (from pin tip to the top of the package). You will need add whatever space you deem necessary for running wires beneath the boards.
Tyler
Old 29th July 2010, 10:23 PM   #3
Default Case Room :
OK . I have a bit less than 3" . Are the caps on the kit for the 3886 in the signal - path ? In other words , is anyhing to be gained by using higher
quality caps ? ( Obviously , some caps might be taller than the chip . )
DVW
Old 29th July 2010, 10:32 PM   #4
No, I'm referring to the power supply electrolytics. Taller ones are used if you want larger values and/or larger voltages (larger sized usually caps have lower ESR). I doubt any that would fit on the board would be 3" tall.
There are some capacitors in the signal path though, but you would have to research and decide which ones you would think about upgrading, and to what. There is an endless selection and and equally endless amount of opinion on what is best.
Tyler
Old 30th July 2010, 01:04 AM   #5
Default Thank You , Tyler .
I build speakers , and I use " fine " caps in the sections in the signal - path ; most often with the High - Pass section . By - Pass a lot with expensive ones. I believe I can here a difference . Some say it is a waste of money. But , it is a " One - Time " expense , and you have to listen to the result for many years , so why not ? DVW
Old 30th July 2010, 01:21 PM   #6
Originally Posted by DaveSail View Post
I want to be sure it will fit in the HAFLER SE120 case I want to use
build one first.
get it working.
Listen to it.
Is it worth building a pair to insert in that chassis?
Then consider how you package all the components to fit.
regards Andrew T.
3886 kit LED replacement remmelt Chipamp 0 10th December 2009 09:00 PM
differences among these chipamps, 1875,3875 and 3886 ttan98 Chip Amps 6 30th January 2007 08:33 PM
LM 3886 stereo kit for the UK pete.a Chip Amps 3 16th August 2005 02:31 PM
BrianGT's 3886 kit, a little help required.. MrSensitive Chip Amps 2 16th August 2005 01:08 PM
Impressions of Snubbered BrianGT 3886 vs Reg 3886 moving_electron Chip Amps 1 23rd March 2005 06:51 AM
Page generated in 0.08317 seconds (67.37% PHP - 32.63% MySQL) with 10 queries
