Old 28th July 2010, 08:40 PM   #1
Default 4580 JRC Add Line Out
I have a DVD Nav Headunit in my Lancer and i want to add aftermarket amps to the radio.. But as you know most factory radios dont have rca out.. line-level out.. So I opened up the unit found the AMP IC and followed the imput to some "4580" jrc chips two of them.. can i solder my rca wires to the output.. do i need diodes capacitors etc this is a car radio..
Thanks for the help..
Old 28th July 2010, 10:48 PM   #2
That's a NJM4580 dual op-amp. It's probably line level out (ie RCA in this case). Whether or not you need capacitors or other parts depends on the circuit surrounding the op-amp.
Given that it's used in a car environment, you should put a capacitor (try 22uF 50V electrolytic) in series with the output followed by a resistor (try ~22k ohm) to ground.
Tyler
Old 29th July 2010, 09:11 PM   #3
It looks like it uses the NJM4580 as a line driver for the TDA7386 AMP.. I dont plan on using the built in power at all so the amp will not have speakers pluged in.. But i do want to use the NJM4580 to output to RCA.. I found pins 11, 12, 14, and 15 to be the Line-IN at that amp ic and pin13 sig ground.. I was just thinking of putting 4 rca cables on pin 11,12,14,15 and ground all of them to pin 13..
Here are some pics i took so you can see what im looking at.. I know the cap the brown ones near the amp run in serial with the am imput one for each they say 224
Thanks for the info..
Old 29th July 2010, 10:24 PM   #4
It looks to me like C107, C127, C147, C167 are all electrolytics in series with the output of the op-amps to block DC.
10uF series -> resistor to ground -> resistor series -> muting transistor -> resistor series -> capacitor to ground -> brown capacitors? (0.22uF)
It's a very typical line out circuit. You can certainly tie some RCA outputs to the TDA7386 input pins. You may be able to find a better (easy to solder) ground point than pin 13. Just probe around likely spots and check for continuity to pin 13.
Tyler
Old 30th July 2010, 12:32 AM   #5
Artie is offline Artie  United States
Actually, those caps are probably on the input pins, as shown here:
The outputs are bridged.
Old 30th July 2010, 01:15 AM   #6
Yes the brown capacitors @ c169, c129, c109 and c149 are on the inputs to the TDA7386 so get the signal after the caps or before?
if the -> in brown caps -> tda7386
Old 30th July 2010, 03:03 AM   #7
Everything I said was after the op-amps, before the TDA. So yes, get your signal on the input pins of the TDA.
Tyler
Old 31st July 2010, 12:48 PM   #8
Here's a thought too: If it was me, I'd prefer not to go into the internals of the head unit. Why not build a simple spkr-to-line-level convertor? With the right selection of resistors, you can keep the TDA7386 down in the 1-watt range, which keeps the THD below .05%. That would be fine in a car environment, and you can adjust the resistor values to get whatever output voltage level you prefer.
Here's one way: (Btw, you want to balance the two speaker-wire output loads since this device is "bridged".)
The two inputs are LF+/LF- speaker outputs. Obviously, you'ld need four of these circuits.
Old 1st August 2010, 12:35 AM   #9
I like that idea Artie.
Tyler
Old 2nd August 2010, 08:21 PM   #10
That is what I had before a "low level converter" but past 1/2 volume we saw distortion on a scope.. plus to me it did not sound good.. i had pop and noise.
well its done now.. I just need to put it back in the car and see what it sounds like I wished I still had access to the scope to see what it does now.. I belive those opamp should be doing around 4volts.. so that should be perfect for my amps..
Op-amp Replacement for 4580 (JRC) tk421storm Parts 17 5th December 2009 07:11 AM
wtb:4580 opams Ryssen Swap Meet 1 18th December 2008 06:51 PM
15 watt amp need to add a line out ferenczy Solid State 2 23rd August 2007 02:46 AM
Transmission Line ADD ONS caratje Subwoofers 10 4th January 2006 09:49 AM
Copyright ©1999-2013 diyAudio
