Old 27th July 2010, 09:15 PM   #1
Boscoe is offline Boscoe  United Kingdom
Default I need a advice for a stereo amp, help needed!
Basically I'm on a bit of a budget but want a stereo amp at least 20Wrms into 8ohm and powered at 24Vdc as I have a lot of these power supplies and don't have the budget to buy a new decent one when I have this amount. the thing is I want a kit one don't ming wether it's pre built or not i just can't find what I need. The LM3886 to power humgry for what I want and dosen't go on 24Vdc but great price and avalibilty. The TDA2050 from sure electronics, great power great price right voltage buts it's from china and I can't wait a month for it. The velleman K8060 amps from maplin good price, but wrong voltage although I have a torodial I can use already, it's just enclousing these and cooling them well enough. I'm thinking of the TDA7377 as it is very easy to make but I have no PCB equipment and can't find any kits. Theres a lot of amplifier kits out there but I can't find many from europe althoguh I only really want to buy from the UK. Thanks a lot just wondered if someone had any suggestions.
Old 29th July 2010, 06:23 PM   #2
Minion is offline Minion  Canada
Well I can tell you from experience that stuff from china doesn"t take a month .... Ive gotten stuff from sure electronics in under 10 days , it is actually quicker from china than some places within my own country .....
Another option would be to etch your own PCB (you don"t need anything specialized accept for a lazer printer and an iron ) or even easier use vero board and source your own parts .....
Cheers
Old 29th July 2010, 06:29 PM   #3
Mooly's Avatar
Anything here,
Your Search Results | CPC
do you mean single supply rail of 24volts or -/+24 volts.
A simulation free zone. Design it, build it, test it.
Old 29th July 2010, 06:39 PM   #4
24volts.
And thanksfor the other advice.
Old 30th July 2010, 02:26 AM   #5
star882 is offline star882  United States
star882's Avatar
Digital Amplifier Solution - Analog Input Class D Amplifier - TPA3122D2 - TI.com
Use two in BTL.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Guitarist goes stereo! Chip advice needed jwdwarren2006 Chip Amps 10 8th June 2008 04:27 PM
Advice plz. for choosing stereo amp elfranche Multi-Way 1 24th September 2006 12:11 AM
Advice needed for amp design gpond Chip Amps 3 29th August 2006 05:30 PM
Advice needed for amp design ifrythings Solid State 26 13th May 2006 01:17 PM
Advice on amp needed HiLLBiLLY Multi-Way 1 12th November 2004 10:13 AM
Page generated in 0.06853 seconds (78.96% PHP - 21.04% MySQL) with 10 queries
