| Chip Amps Amplifiers based on integrated circuits |
#31 |
OK Pin 3 0v DC, goes direct to the positive on the woofer, no further fuses between it and woofer
#32 |
Yep, got a bit of time so just have a measure and see if you can trace that connection to pin 3.
Does it go to the speaker directly ?
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#33 |
OK... and also confirm that the negative terminal of the woofer actually returns to ground... just to make sure no fuse in the ground connection.
And with the amp OFF and woofer connected you should be able to read on ohms the resistance of the woofer (just to make sure that's OK) between pin 3 and ground. If you then use diode check to do same you should hear the woofer "click"
#34 |
It does, there is a sideline to a resistor then back to another pin on the IC, but no interuption between pin 3 and speaker
#35 |
OK so it clicks... so woofer is good and connected OK.
Is the IC new ? Now a scary test... with it on and connected to the woofer what happens if you VERY CAREFULLY as in steady hands, touch a metalic screwdriver to just pin 10 of the IC. Make sure you are not touching anything else... there's no shock hazard... we just want you buzzing that input with no other voltages superimposed. That is attempting to "buzz" the input and see if any response from speaker.
#36 |
3.5 ohms pin 3 to ground of speaker on pcb, very faint crackle in speaker on diode check. Not sure with the grounding qn, where do i put pins to check this have been using speaker ground as ground for all measurements
#37 |
IC is new, just used the negative probe to touch 10, no response, have i done right?
#38 |
3.5 ohms sounds correct. The correct ground is the 0 volt line (which will probably be the speaker return as you are using). It's that large area of print above the 1 and 2 in the picture where the two large caps have a common connection. If that reads 0.00 ohms to the speaker negative then it's OK to use that as it will be easier probably.
#39 |
You have done right but there should be response... so now we have to measure all the pins on the IC for DC voltage and see if anything seems amiss.
What's the DC voltage on pin 8 first though ?
#40 |
Yep that is the one I am using, checked and 0 ohms between that point and the negative output from transformer
| Need help to fix this amp DIY | Joseph R | Class D | 11 | 9th March 2011 09:54 PM |
| Help a noob fix a ZV9 | neil_kaye | Pass Labs | 46 | 2nd January 2009 06:56 PM |
| Perpetuum-Ebner PE66: To fix or not to fix... | Grendel the Cat | Everything Else | 0 | 6th April 2007 05:37 AM |
| Does this amp look to be hard to fix? | mazeroth | Solid State | 6 | 30th August 2006 05:12 PM |
| help needed to fix amp! | marko | Car Audio | 28 | 19th October 2005 04:53 PM |
