Old 23rd July 2010, 07:02 PM   #1
Default Toroidal Amp Question :
I am planning to build a Chip Amp using two LM3886 chips .
Separate power supplies and bridges .
" NUUK " has a list on his page for dummies . For 8 Ohm
speakers , 20 to 25 Sec. Voltage . 80 to 300 VA per channel
Plitron site . Standard list . # 077016201
2 x 25 VAC . 300 VA
Would a pair of those be correct ? [ I can work out dual
switches . ]
They also list " Low Noise For Soild State Amps " .
Would a pair of those be prefrrable ??
TIA ; David V. Webber
Old 23rd July 2010, 07:50 PM   #2
two 300VA 25+25Vac transformers for two 3886 chipamps is about as good (best) as that anyone would recommend.
Most are built successfully with far smaller transformer/s
Go ahead if you think these give you value for your money.
regards Andrew T.
Old 25th July 2010, 01:52 AM   #3
I don't know a lot about electronics . Just felt as a V - 6 or a V - 8
gets less wear / sress than a V - 4 doing the same work , it might be
the same with TFMRs ! David
Old 25th July 2010, 07:27 PM   #4
This amp will be for my " Bedroom " speakers . They are very efficient .
JBL LE14A Woofer and LE85 Mid / High . May add a pair of Slot Radiators .
They both have massive magnets and large voice - coils . My 1 Watt
Clock Radio will drive them such that they shake the walls !
However , quite often folks ask to borrow an amp . Perhaps for a Audio - Video
presentation or for an outdoor picnic or such . So , for those occasions I think
it would be good to have the larger XFMRs . David
Old 25th July 2010, 09:41 PM   #5
infinia is offline infinia  United States
infinia's Avatar
Dual over sized XFMRs are not the most Eco friendly solution. IMO
well if you can coax 70W/channel of audio output from a chip amp at 60% eff I would shoot for ~150 VA / channel taking into careful consideration the rail voltage droop under load. If you combined the 2 into one 300 VA XFMR the rail will be stiffer ie better regulation.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 26th July 2010, 12:02 AM   #6
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
As far as I'm aware, transformers do not wear out. I agree with AndrewT and infinia - 300VA is overkill here. My active speakers have 150VA for two LM3886 per channel (bass/mid and tweeter) and work just fine.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 26th July 2010, 03:59 AM   #7
Super . What would be the PLITRON part number for those ?
There are a LOT of units in their catalog ! TIA DVW
Old 26th July 2010, 04:46 AM   #8
infinia's Avatar
You could buy a single 300VA or 2x 150 Antek brand for saving big $$.
AFAIK they are equal to PLITRON at the standard ship now series.
Spend a moment at their site its really not too hard to figure out the P# scheme.
Question about toroidal transformers 00940 Power Supplies 15 19th February 2009 03:21 AM
Toroidal transformer bolt question & mobile phone interference markiemrboo Chip Amps 19 5th December 2006 11:15 PM
Question: Toroidal transformer rating siuguyguy Power Supplies 4 26th September 2006 02:08 AM
Question- Toroidal 25vac (ebay) whitewind Chip Amps 3 18th December 2004 12:52 PM
toroidal question saletel Chip Amps 1 15th December 2003 09:38 PM
Page generated in 0.09332 seconds (80.08% PHP - 19.92% MySQL) with 10 queries
