Old 23rd July 2010, 11:16 AM   #1
Atilla is offline Atilla  Norway
Soldering Gun Fanatic
Default Opamps, aren't they a lot of fun sometimes?
A bit of a funny situation here.
I've been running a PIMETA headphone amp for .. a very long time. No problems at all, no noise, no DC offset to worry about.
Recently I thought I would check what would happen if I swapped my ground channel opamp - OPA134 with an OPA627 to match what's in the left/right channels. I found a couple and decided to try.
I couldn't spot difference - I mean, come on, they're almost the same thing anyway, plus this is the virtual ground channel and should theoretically matter less. Except that with the OPA627, things got weird. It was dead quiet without input signal (input not shorted but not connected either). Same thing happens with the OPA134. With signal though, it got noisy at higher volumes. "Noisy source" you'd think, but no - with the OPA134, the noise from the source (PC sound card) can be felt only at the highest pot position. And then - when you turn off the power with the OPA627, a high-pitched whine shows up, like turning off an old TV set. With the OPA134, a very slight "thump" can be felt, since the capacitor bank of my PIMETA is after the power switch and they take a little to drop charge after you flip the switch off.
So, apparently the those OPA627 i tried weren't stable in this ground channel, in my amp. Funny though, I wouldn't expect that to happen.
EDIT: Oh, I know OPA637 wouldn't be stable in unity gain, but the ones I've got clearly say 627 on them, I double-checked
Old 23rd July 2010, 11:23 AM   #2
but most reasonable and right thinking designers would expect a straight swap of opamps to require sorting!
regards Andrew T.
Old 23rd July 2010, 11:29 AM   #3
Okay, you got me - what is "sorting" in this case?
And don't worry, those opamps aren't going to waste, they're for another project.
I just need to keep reminding myself - "if it ain't broken, don't try to fix it".
Old 23rd July 2010, 11:32 AM   #4
start by comparing the spec differences between the two opamps.
Then pour over the manufacturer's implementation recommendations and note any differences.
regards Andrew T.
Old 23rd July 2010, 02:30 PM   #5
Joachim Gerhard's Avatar
Try to put a 10nF cap from Pin4 to Pin7. If that does not help, try 0.1uF.
Old 23rd July 2010, 02:36 PM   #6
Well, 627 has got 1/2 the noise and double the slew rate. The first parameter isn't a problem while the speed could potentially be. It's just that other people have used the same board and chips without issues, so I thought I'd share the story.
I'd add some local bypasses but for that I need to disassemble the amp. I'm sure I'll break something if I do though, so it's more likely I'll see how this goes on the next headphone amp I build. Or ... I could directly bypass it on the pins ... hmmm ... Ceramic NP0 should be fine, right?
Old 23rd July 2010, 02:52 PM   #7
are they the only differences?
What is slew rate?
It's the amps ability to change voltage with time.
If the amp has any capacitance to charge then a doubled slew rate ability implies a doubled current demand.
A doubled current demand requires decoupling to suit. See what the manufacturer recommends. POUR OVER the datasheet.
regards Andrew T.
Old 23rd July 2010, 03:11 PM   #8
Two things could be the culprit here:
Missing local bypass caps for the opamp - they're always good to have, but in this case it's not driving a load directly, the buffer is.
However, the BUF634 that's used must be in wide bandwidth mode with fast opamps and the OPA627 is quite faster than the OPA134. IIRC my buffers have a bandwidth limiting resistor, which keeps it pretty high, but not at maximum.
Now that I remember that, I bet it's a combination of both.
Old 23rd July 2010, 03:19 PM   #9
diyAudio Moderator Emeritus
jean-paul's Avatar
Without proper decoupling OPA627 I would not even bother to try it as you know beforehand it won't perform as it should. It is one of the most sensitive opamps for decoupling (with or without another chip driving the load). I really do not understand why people use high speed high bandwidth parts without even reading the datasheet or adhering to the basic requirements. To me these cases sound like one is complaining about the performance of his diesel car after having it filled up with petrol Indeed opamps can be a lot of fun when used right.
A 10 to 47 uF good quality low ESR electrolytic cap from + to GND, again one of those from - to GND and finally one 10 nF to 1 uF film cap ( I often use 10 or 100 nF Wima MKT 5 mm pitch as they fit perfectly) from + to - directly on the pins will do. The latter is quite important. Then check again how it works.
It's only audio
Old 23rd July 2010, 04:50 PM   #10
jcx is offline jcx  United States
The Pimeta’s "3-channel" topology is fundamentally flawed - most technical reasons given for it are simply not true or can be bettered by proper layout
"active supply splitter" can be useful when wanting to use single V supply - the single active gnd should be used for input, feedback and load gnd
but "3-channel" puts the gnd “buffer” amp in series with the load - with the input and feedback grounds separated from the load gnd - this means all of the error of the "output gnd" buffer is in series with the headphones - giving distortion and "output gnd" impedance crosstalk that is worse than with a good "passive" gnd of heavy conductor with signal input gnd, feedback gnd "star" connected with the load common ground pin of the TRS connector
A "active gnd" showing star at output - can better "3-channel" performance:
particularly with the near 2000 uF of supply C of the Pimeta on the "input gnd" adding a buffered "output gnd" is a waste - just calculate and add a series R for the tle2426 that keeps it from going into current limit with your cans and the supply C with 20 Hz full scale signal - this gives a AC gnd at audio frequencies, cuts AC current draw in half vs active or 3 channel gnd
without a oscilloscope you really can't tell what's causing your observed problems - but I wouldn’t' give any weight to the noises you get after the power is removed - details of drop out behavior as the op amp supply V drops past the minimum data sheet spec isn't a good reason to choose audio op amps - if its a big problem then add a output relay or power supply crowbar - or just unplug the phones 1st
FS: Final Lot of Opamps seiko_citizen Swap Meet 19 5th June 2008 01:38 AM
Lot of help please dudeinaroom Pass Labs 2 25th October 2007 12:16 AM
FS: Power Chip OpAmps and other OpAmps & D to A Converter dtm1962 Swap Meet 4 12th January 2006 10:07 PM
Bypassing a lot of opamps Devil_H@ck Chip Amps 10 28th July 2004 01:36 PM
Page generated in 0.11480 seconds (81.05% PHP - 18.95% MySQL) with 10 queries
