Old 22nd July 2010, 11:35 AM   #1
Unhappy Gainclone traffo wiring problem - help needed
Hi
Wired my Antrim 300 va 25v traffo secondry wires in series as per the Antrim wiring diagram and the +ve wire after rectification reads 66 volts.
This was measured when NOT connected to the amplifier boards ( unloaded )
So, to my simple mind I have -25 v plus 0v (centre tap) and + 25 v which should give me 35.35 volts rectified.
Is my 66 volts actually 25 v + 25 v = 50 X 1.414 less a few volts for rectifiers and caps ?
Have I got it wired 0 v - 50 v + ?
Is this wrong ?
The amp works well when this it's connected in this way.
I don't mind being berated if it means I can get it right or....just understand
what my measurments mean
Andrew
Old 22nd July 2010, 12:01 PM   #2
bobodioulasso's Avatar
I think you measured 66v across + and - rails.
which means +33v/ 0 /-33v.
Yo have to measure from ground (0v) to each rail.
Old 22nd July 2010, 12:32 PM   #3
Hi
Thanks for her reply.
I measureed form 0 v to +ve.
Hope this helps
Andrew
Old 22nd July 2010, 03:59 PM   #4
Could you show a diagram ?
Old 22nd July 2010, 04:37 PM   #5
Hi
Thanks for the reply.
I've just fixed it and all is well.
It was something stupid which I've corrected and learnt from.
I'll try and remove this thread now....but thanks to all
Andrew
Old 22nd July 2010, 04:42 PM   #6
Talking Gainclone traffo wiring problem - is now fixed, don't replyly
Fixed !
Old 22nd July 2010, 06:02 PM   #7
tell us what you did that was different.
That way the rest of us can benefit.
regards Andrew T.
Old 22nd July 2010, 07:45 PM   #8
Andrew, please don't do this !!
I can almost feel your foot ready for my *** here !
OK, I did exactly what Bobodioulasso ( a few threads up ) thought I may have done.
I did not use my meter correctly and I'm really red faced.
I said ' fixed it ' becasue I thought I'd done something potentially very dangerous and hurriedly switched it off.
Stripped out the traffo from the case and double checked my Antriim wiring for centre tap and two 25's - it was as per the drawings.
Put it back in, used the meter and had an ' ohhhh s...t ' moment.
It was fine after all.
Have you ever had one of those moments or is it just me ?
One day, I promise....I'll post a worthwhile and intelligent thread.
Hundreds will post fantastic replies and I'll really feel part of this community.
I'm so out of my depth but my Gainclone is lovely, thanks to this site and you on occcasions.
Music came out first time and it sounded a lot better than the rubbish I had already ( pic attached somewhere )
Thanks for the shove !!
Andrew
Patek gainclone, upgraded wiring and posts Ang Swap Meet 0 6th July 2008 01:12 PM
Wiring help for an all-in-one gainclone neil_kaye Chip Amps 2 24th August 2006 03:15 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 02:46 PM
problems wiring Brians gainclone kit Jimmy D. Chip Amps 9 12th December 2004 01:47 AM
16 chip gainclone wiring Matttcattt Chip Amps 32 23rd July 2003 04:40 PM
Page generated in 0.09870 seconds (78.74% PHP - 21.26% MySQL) with 11 queries
