| Chip Amps Amplifiers based on integrated circuits |
I am building a 3 channel power amp for my screen porch (left, right and sub) and want to use sanyo modules. my question is what is the difference between the v,II,XI designations? there is quite a price difference. I would like to use stk4044(100w) for the left and right and stk4050 (200w) for the sub. that should be enough power to give the neighbors a stroke!! any help would be appreciated. thanx
#2 |
See PM.
The truth is out there. Who can handle the truth? |
#3 |
hi, could you please tell me what the difference s between the 4050 I II and V
#4 |
As far as i know 4050 only comes as the"v" model. in the other stk series chips the I II and v designation refers to better thd numbers.
#5 |
Hopefully they didn't do the same as in the STK30X2 ( STK3042, STK3062, STK3082. STK30102 ) driver chip series. Later versions lacked internal compensation circuits (caps and resistors) so had to check the data sheets very carefully to see what was needed to add to the circuits. (or suffer from serious oscillation) Good luck.
Steve |
#6 |
Steve, what was wrong with the STK30x2 etc. drivers? I have the original datasheets and the VAS compensation is a bit weird.
#7 |
Nothing is wrong with them but - the original version has internal compensation caps and resistors between pins 3-4, 12-13, 4-6, and 10-12. The type ii are functionally equivalent, except there isn't a resistor and cap between 3-4 and 12-13 and in the type iii all are not there. So if subbing for a type i, with a type ii need to add an R-C in each channel, and when using a type iii need to add an R-C and a second C. Use the values in the test circuit in the type iii data sheet (68 pF + 470 ohm for the RC, 15 pF for the C) and amp won't oscillate.
Steve |
#8 |
Hi guys can anyone help me out? More or less how many degrees per watt should the heatsink for a single STK4050 be?
#9 |
Depends on the rail voltage, load impedance, ambient temperature and whether the heatsink is outside or inside of the amplifier case.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#10 |
Pacific blue is correct many variables exist but as a rule of thumb ic power dissipation is equal to 1/10Po max for real world applications. thermal resistance is 1.2deg C/W. Total power dissipation on a stk4050v chip is around 240 watts. Of course when it comes to heatsinks bigger is better. good luck
| Sanyo to sell chip unit to On Semi | EUVL | Parts | 4 | 8th July 2010 03:50 PM |
| how to use Sanyo chip amps? | CharlieLaub | Chip Amps | 2 | 3rd March 2010 07:41 PM |
| Boat Amp! Sanyo LA4508 8.5w chip | oublie | Chip Amps | 6 | 28th June 2009 05:47 PM |
| Clarion car stereo problem - bad Sanyo LA4743B chip? | GirchyGirchy | Chip Amps | 4 | 22nd August 2005 06:41 AM |
| Help needed with old Sanyo STK chip amp please | georgehifi | Chip Amps | 3 | 3rd September 2004 09:14 AM |
| Page generated in 0.09375 seconds (78.70% PHP - 21.30% MySQL) with 10 queries |
