Old 16th July 2010, 02:46 AM   #1
Arx is offline Arx  Canada
Default Resistors required on parallel amp
I'm building an amp with a paralleled 3875, and I was wondering if 2 of the ,1 ohm resisors are required.
It seems to me like one of the chips could be connected directly for marginally better efficiency and damping, and the other run through a 5W 0r1 resistor. Any thoughts?
Old 16th July 2010, 04:10 AM   #2
jcx is offline jcx  United States
Default they aren't called current sharing resistors for nothing
due to high negative feedback each chip will have miliOhm output Z at low audio frequencies - leave out one of the 100mOhm R and the direct connected chip amp will supply 99% of the output current
Old 16th July 2010, 04:19 AM   #3
star882 is offline star882  United States
star882's Avatar
They're required for bipolar and certain IGBT output stages, but not MOSFETs. I think the chip in question uses bipolars so yes, you'll need them. And you'll need to synchronize the drive signals.
"Fully on MOSFET = closed switch, Fully off MOSFET = open switch, Half on MOSFET = poor imitation of Tiffany Yep." - also applies to IGBTs!
Old 16th July 2010, 05:50 AM   #4
sasmit is offline sasmit  India
Send a message via Yahoo to sasmit
when you're paralelling the idea is that each amp shares exactly..nearly half of the load current. In practice due to unavoidable differences between output devices, one of the devices is going to provide all the current. To avoid this and force load sharing these resistors are required, without these you'll end up using only one amp.
Old 16th July 2010, 06:00 AM   #5
lgreen is offline lgreen  United States
lgreen's Avatar
yeah, what they said!
And make sure to use at least 1% resistors, they need to match closely or one device will still hog all the power. Your input and feedback resistors should be matched to about 0.1% or better or the chips will have different gain, different outputs and all he** will break lose.
My DIY audio projects- PartTimeProjects.com.
Old 16th July 2010, 11:06 AM   #6
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via MSN to abraxalito Send a message via Yahoo to abraxalito Send a message via Skype™ to abraxalito
1% 0.1R resistors will be expensive, if you can find them. Fortunately they're not necessary, 5% is fine.
Even with 0.1% gain setting resistors, any imbalance in current sharing is going to be mainly due to these resistors and not the output sharing resistors. (With 0.1R sharing resistors, I recommend 0.05% gain matching.) 5% is plenty good enough for the output resistors - I've simmed it
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen
Old 16th July 2010, 11:34 AM   #7
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Of course not. Let's put in some numbers: If the gain of one amp is 10% higher than the other, and the sharing resistors are exactly the same, one amp will provide 10% more current than the other. No ideal sharing, but more than good enough (and of course 10% gain difference is huge and will never happen with 1% feedback resistors).
Now let's take the sharing resistors. Assume perfect gain matching but 10% share resistors accuracy. That means, assuming 4ohms nominal load, one amp sees 4.1 ohms and the other, say, 4.11 ohms load. So the sharing inaccuracy is tiny and you would have a hard time to even measure it.
So it's clear that these are non-issues.
jd
/Another new issue: Linear Audio Volume 3!
Old 16th July 2010, 12:34 PM   #8
abraxalito's Avatar
Looks like you put in the wrong numbers. The gain matching is substantially more sensitive than this - to see though, we need to convert the gain mismatch into a voltage mismatch at the outputs. 10% gain mismatch (not the worst case with 10% resistors, which is 20% mismatch) becomes 10% voltage mismatch, take the peak output voltage to be 28V (a 50W/8R amp). 10% of 28V is 2.8V, this appears across two 0.1R resistors in series giving a current of 14A. Its clear that both amps are well into mutual destruction - the paralleled amp looks just like a load resistor of 2R to the other amp. Even with 1% resistors the current can be 2.8A (one gain can be +1%, the other -1%).
<edit> seems like a quick rule of thumb is multiply the sharing resistor's value by 100 and divide by the tolerance of the gain resistors to see the worst case effect of mismatch. e.g. with 1% we get an equivalent 10R load seen by the other amp.
Old 16th July 2010, 12:42 PM   #9
janneman's Avatar
Yes, you are right - didn't realise that the outputs are connected through the 0.1R.
In that light, maybe 0.1R is a bit too low for safe sharing with realistic gain matching?
jd
Old 16th July 2010, 12:46 PM   #10
abraxalito's Avatar
That's my view yeah, I suggest 0.2R as a minimum when using 0.1% types. But that's the ultra-conservative engineer in me, in practice few people will encounter the worst case scenario.
<edit> the other thing people often forget (even the writers of NS app notes on paralleled amps) is that the gain often has frequency dependence at LF introduced by electrolytics, these have far worse tolerance than even lousy resistors
Required heatsink for 3 LM3886 in parallel? CJ900RR Chip Amps 7 2nd January 2009 05:19 PM
Parallel TDA1541A ... some clarifications required skje Digital Source 3 25th March 2008 01:11 PM
Parallel DACs: How many I/V resistors ? Bernhard Digital Source 7 18th March 2007 12:48 PM
Resistors -- using higher-than-required watt rating slowpogo Parts 5 12th January 2007 08:28 PM
Page generated in 0.11876 seconds (86.92% PHP - 13.08% MySQL) with 11 queries
