Idea for a 255 step attenuator, is it good ? - Page 3 - diyAudio
Old 9th July 2003, 04:30 PM   #21
Originally posted by janneman
Hi Mark,
Yes I was referring to the error you get when trying to get linear-in-dB range with binary steps. But your curves are not that bad. What about using one extra relay to switch the 22ok between two values? You could use the 18-32dB range of the 4 bit thing, which is pretty linear, and use the extra relay to say shunt the 220k with a resistor to lower the gain by 18dB, bringing your linear range to full 32dB. Does that make sense? It would mean you need some logic because you no longer have a nice binary count. Or maybe you do have if the extra step is made 16dB.
Jan Didden.
Ah - "monotonic" means constant rising steps as the input rises (eg 00111111 must give a lower voltage than 01000000). It doesn't mean constant step-size. This is why I was confused when you said it wouldn't work before - I knew that it would be monotonic, but wasn't sure about step size...
The more I think about this scheme, the more I like it. If you wanted a less "purist" implementation, CMOS switches could be used around the virtual earth... I'll be trying this soon.
Mark
Old 9th July 2003, 06:01 PM   #22
Account Disabled
Hi
I am pleased to read this thread, as we have been producing a preamplifier with a 64 step relay / SMD resistor attenuator for years. It works great, and has very good linearity (<0.5dB).
We don't use the circuit proposed by Mr. Hennesey, as it does not give us the desired linearity.
However in our Sidewinder preamp, we use a combination of ladder and feedback attenuation (to optimize for noise performance). You can download the user manual with schematics of this attenuator and preamp here:
http://www.lcaudio.dk/sidewind.PDF [3.5 Mb]
Maybe not perfect graphic quality, but i think you can get the principle of this ultra high performance pre-amp.
All the best from Denmark
Old 9th July 2003, 06:26 PM   #23
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
Equal sized steps (linearity?) ends up adding too much complexity.
The biggest advantage is a useful balance control function, but lots of people don't seem to need this so I don't think it is worth it. We don't need a huge number of steps either. Remember the chip amp credo: Not one more part that is necesary.
"The geek shall inherit the earth"
Burning Amp thread here on diyAudio
Old 9th July 2003, 06:40 PM   #24
Account Disabled
Exactly!
1.5 dB per step. ( times 64 steps = max 94.5 dB of attenuation).
LC
Old 9th July 2003, 08:41 PM   #25
diyAudio Editor
Variac's Avatar
I suspect I could live with 15 steps if that is the simplest
Old 10th July 2003, 12:35 AM   #26
Account Disabled
Maybe 3 steps could be even simpler for you ?
Old 10th July 2003, 02:25 AM   #27
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I'm using 5 steps and it's enough
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 10th July 2003, 02:35 AM   #28
Bill Fitzpatrick's Avatar
I used 12 stepper for years and found no drawbacks.
Old 10th July 2003, 11:18 AM   #29
It's hard to see what you are doing because of the quality of the image - could you post a better quality image?
So I might be wrong, but it looks rather like you might be using cascaded constant impedance attenuators. If this is the case then I'm glad - I tried to make the case for them in this post
Originally posted by Variac
Mark H,
I like the simplicity of your calcs. After all, if we want &quot;everything plus the kitchen sink&quot; we should just get Apox's.
Thanks So do I - I'm definately going to try it at some point in the distant future...
I'd really appreciate a schematic that is totally clear, very simple, with parts values so even a gainclone guy could build it!
Here it is! I've left out details like PSU - I'm sure you gaincloners can work out those bits. And someone else can decide on a control scheme, but for testing you don't need to use relays, you could just try simple switches (remember to operate them in a binary sequence!). A real implementation would require some pushbuttons, a 4-bit binary counter (TTL or CMOS, but could be a PIC or AVR complete with display and IR decoding!) and some transistors or similar to drive the relay coils. As I said before, consider CMOS analogue switches for less demanding applications...
Mark
PS - you can readily buy 10K and 20K resistors - you might have to connect some up in series to make 40K and 80K. Having said that, I just dialed in 39K and 82K into my simulation and it made very little difference to the curve. The 20K was more critical, so I'd recommend you stick to that value...
Old 10th July 2003, 10:34 PM   #30
diyAudio Editor
Variac's Avatar
This reminds me of my high school days on the early 70's .
We were into bike racing and would spend hours calculating gear ratios. In theory they were ten speed drivetrains but in fact had lots of overlap and duplications, so a clever design and complicated shifting sequence could get you about 8 real ratios.
The sequences were so arcane that some had a little chart taped to their handlebars. Now of course bikes have a whole bunch of gears, so you have so many ratios you can't go wrong!.
I probably will try this and tape the sequence to the front panel of the amp!
I'm sure that would lead to some full volume blasts!
So who does the simple control devices- APOX again? Maybe their intro product I'm sure someone else can come up with this easily; right? I can't hear you!!
Mark Cronander
24 Step Attenuator poynton Parts 1 9th January 2008 07:26 AM
23 step attenuator tryonziess Chip Amps 2 21st May 2007 12:33 PM
Alps step attenuator kmtang Tubes / Valves 5 30th May 2005 11:51 AM
DIY 40 step attenuator, anyone interested in such??? Magura Parts 64 20th August 2004 03:25 AM
Copyright ©1999-2017 diyAudio
