which wires to twist?
Old 29th June 2003, 06:42 PM   #21
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Thought I needed to chip in:
Just a note of caution: don't overdo the twisting thing for you're going to create capacitance on the wiring that may play some odd tricks on you.
\Be ware of Mr. Miller.
Frank
Old 29th June 2003, 08:28 PM   #22
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
how can i "over do the twisting"?
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 30th June 2003, 02:12 AM   #23
fdegrove's Avatar
Basically in several ways:
Twisting a lead that carries audio signal and feeding it to sonething doesn't feel happy with too much capacitance on the input.
Be aware that this capacitance may vary from channel to channel which in turn may alter frequency response between channels.
There's more to say but let's say that twisted leads may be used irresponsibly.
Frank
Old 30th June 2003, 05:54 AM   #24
Jennice is offline Jennice  Denmark
Frank,
I understand your concern and where you're heading.
However, this thread is heading in a slightly different direction
We were mainly talking about the power supply conductors, and with these impedance levels, the naughty boy "Mr. Miller" can go and play elsewhere. (To put things as politically correct as possible here *grin*)
You're totally correct that twisting can give you a headache if one is dealing with small signal cables. (Mr. Miller then goes: )
However, when it somes to signal cables, I would choose to use a coaxial signal cable (not meening the stiff antenna cable), but the flexible stuff. Just make sure it's with a weaving (word?) structure shielding (the stuff that goess criss-cross). If you use the shield that is just spinning around in one direction along the inner conductor axis (rolled on) , you may get into problems.
Jens
Old 30th June 2003, 06:01 AM   #25
Nuuk,
I got your email, and will get back to you when I get back home in the evening.
Jens
Old 30th June 2003, 10:05 AM   #26
IanHarvey is offline IanHarvey  United Kingdom
Default Re: Twisting the field away...
Originally posted by Jennice
When a positive signal is applied to a non-inverting class B amp, the current runs from the positive supply rail through part of the output stage, then to the speaker, and back to the speakers negative terminal. This terminal is a ground line. NOW the ground is "actively" participating as is conducts current
It's worth nothing that in a class-B amp, current flows in a loop between PSU +ve and ground one one half-cycle, and PSU -ve and ground on another. So it's especially critical that +ve and -ve are close to each other, otherwise the resulting magnetic field will be a half-wave rectified version of the signal. This will contain lots of distortion products, which are much more likely to be objectionable (than, say, the field produced by the speaker output lead and its ground return).
Cheers
IH
Old 30th June 2003, 06:26 PM   #27
Default Re: Re: Twisting the field away...
Exactly
With all due respect, Ian, you just proved yourself wrong in your posted statement.
Let's look at the "positive" half cycle:
The current flows from PSU+ through the amp and load, and then back to GND.
In this situation, the high current flows "out" (as seen from the supply wires) at PSU+ and returns through GND. Therefore the "couple" to keep together would be PSU+ and GND.
The wire at PSU- is not "active" (apart from the relatively small circuit supply current) and can therefore be neglected.
In the negative half, the current runs "out" from GND and returns at PSU-, which has a relatively lower potential than GND. In this half cycle, PSU+ is not "active", and the twisted couple should therefore be GND and PSU-.
The only way to obtain both is to twist all three together.
If you only twist PSU+ with PSU-, you obtain exactly what you describe in your text (quoted above). As you said yourself, only PSU+ OR PSU- is active at any given time. The resulting field is then a result of only one active conductor, wile the current's return path to the PSU is not included in the twist you describe. At any given time (except when crossing through zero or when no signal is applied), the GND wire is an active conductor at "full time", while the two PSU + and - take turns being active.
Please read my original post again, and think it over again. The sum of currents from one point (electrons arriving + electrons leaving) is always zero. Otherwise you'd have an eternal power source, which I'm sure you could sell to the world for a good price.
Jens
Old 30th June 2003, 07:18 PM   #28
RobM is offline RobM  United States
Send a message via AIM to RobM
Try it and test noise performance. Don't bother making all these theories and models. Whatever works best, do.
It's one of the greatest luxuries being a DIY-guy (or gal).
Old 1st July 2003, 05:24 AM   #29
RobM,
Another great thing about DIY'ing is that everyone does as one pleases. What ever does the trick for you
Personally, I prefer to revove the most obvious interferrence sources before turning to magic.
Old 1st July 2003, 10:03 AM   #30
Default Re: Re: Re: Twisting the field away...
To clarify what I meant: if you twist PSU +ve and PSU -ve, you end up with the equivalent of one conductor which carries the output current going to the speaker. If the return ground wire is not near this, there will be a resulting field, but it will be linearly related to the signal (i.e. sine wave in = sine wave out).
If, however, the +ve wire is not near the -ve wire, there will be a resulting field and it will be non-linearly related to the signal. My general point is that you can tolerate much more of the former than the latter: a 1% deviation in frequency response (corresponding to a purely linear error signal) is vastly less audible than 1% distortion.
Cheers
IH
which wires to twist?Hide this!Advertise here!
Heater circuit - to twist or not to twist Rob11966 Tubes / Valves 19 20th July 2008 02:08 AM
Deep HT Sub With a Twist bjackson Subwoofers 15 8th August 2006 07:41 PM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 06:47 PM
Is it ok to twist the powersupply wires around each other? bm_mode Solid State 10 16th October 2002 08:49 AM
