which wires to twist?
Old 27th June 2003, 03:30 PM   #11
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
which wires should i twist?
a. +v and ground
b. -v and ground
c. +v and -v
d. signal and ground
e. output and ground
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 27th June 2003, 04:00 PM   #12
carlosfm is offline carlosfm  Portugal
Banned
a. +v and ground
b. -v and ground
c. +v and -v
Matttcattt,
1. Twist the 3 psu wires.
2. Twist signal and ground.
3. Twist output and ground.
Clear?
Let's all Twist together!
Old 27th June 2003, 04:33 PM   #13
e.lectronick is offline e.lectronick  United States
e.lectronick's Avatar
Lightbulb How about Shielded Coax?
Something I read in Kevin O'Connor's book "The Ultimate Tone" might be applicable here...
In his discussion of the wires supplying heater filaments for tubes, he suggests twisting the wires together very tightly to reduce stray 60Hz hum from getting into signal wires, but he then suggests an even better solution would be to use shielded coaxial cable for power runs. You would connect the shield to chassis ground, connecting the twisted pair as you would normally do.
Belden makes a several different twisted pair coax cables with a seperate shield/ground that would fill the bill nicely. It might be overkill, but I've always believed that overengineered projects are better than underengineered ones. As Peter Daniel has said, it's all in the listening, though. So, I may be wrong.
Cheers.
-Erik.
-Who put the Tribbles in the Quadrotriticale?
Old 27th June 2003, 04:40 PM   #14
Banned
Talking talking about overkill...
Supra LoRad.
Old 28th June 2003, 12:40 PM   #15
Jennice is offline Jennice  Denmark
Nuuk,
You're welcome to use my description ;-)
MatttCattt:
I surely hope your signal wires are the "normal" coaxial (shielded) signal cables.
In that case there's no twisting to so there. (signal cable as in signal from input terminal to PCB).
In your PSU, twist the wires from the transformer to each rectifier bridge, and the wires from the bridge to the capacitors.
The wires from the capacitors to your PCB / output stage can be twisted (together with the ground conductor which would most likely be going to your bridge rectifiers as well). This length would then include 3 wires twisting along (V+, V- and GND).
Some of the PSU wires can be done in the "stiff" conductor used in fixed household installations. They're flexible enough to twist, but stiff enough to remain together and make a nice routing inside your amp.
No, they're not Oxygen Free Copper, No they don't have a fancy name on them,
No, they are never mentioned in any High end reviews,
But they make the world turn, and should be fine for the PSU purpose.
Happy twisting
Jens
Old 28th June 2003, 04:25 PM   #16
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
Thanks Jens. I'll try and collect enough similar topics together. Perhaps one day, we will have a difinitive collection of DIY hi-fi topics in one place! A sort of online bible.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 29th June 2003, 05:17 AM   #17
Hi Nuuk,
I dropped by dB dungeon, and it looks interesting.
I've thought about setting up something similar, but never found the time and suitable online space for it.
I also have my own oppinions about cable quality - whether or not there's more to it than L, C and R (which I claim there is not; not to a level of relevance that is).
However, I'd be stoned to death by most of the people in the debate thread about this subject...
Feel free to email me at
jens@sylvestREMOVE_THIS.net
to discuss articles for your site.
Jens
Old 29th June 2003, 08:19 AM   #18
Nuuk's Avatar
Hi Jens, I just tried to email you but that address was rejected by the server for some reason.
Old 29th June 2003, 03:25 PM   #19
Matttcattt's Avatar
thanks for the explination.
Old 29th June 2003, 04:00 PM   #20
Nuuk,
If I've done it right, you should now be able to email me via the diyaudio email link.
Did you remember NOT to type the "REMOVE_THIS" part of the address?
I received the notification about the new post by email as usual, so something's odd here.
Jens
which wires to twist?Hide this!Advertise here!
Heater circuit - to twist or not to twist Rob11966 Tubes / Valves 19 20th July 2008 02:08 AM
Deep HT Sub With a Twist bjackson Subwoofers 15 8th August 2006 07:41 PM
Conductors (I.C.'s, RCAs, internal wires, speaker wires) bigphil Parts 1 25th November 2005 06:47 PM
Is it ok to twist the powersupply wires around each other? bm_mode Solid State 10 16th October 2002 08:49 AM
