| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I am about to build a new stereo power amplifier with two integrated circuits. I know that it is better to use two transformers with two individual rectifier circuits, but i would like to avoid the cost of a second transformer. I am wondering if I will get better stereophonic figure by using one transformer and two seperated rectifier circuits in order to have seperated grounds for the two individual channels, instead of using one transformer and only one rectifier circuit for both channels. I mean, will the difference be detectable? |
#2 |
just another
I went down this path with my LM3886, I think it is a good middle ground. Provided that you have an appropriately sized transformer and a reasonable amount of capacitance in each channels separate rectifier/cap bank then I think that the result should be better stereo separation. (based on the premise that the modulation of the power supply by each channel will be isolated to their own individual cap banks), whether this premise stands up or not I'm not sure.
I did not however have separate grounds choosing to have the star ground common to both channels (but all returns separate). As I did not build a single supply I can't make comments as to whether there's any audible difference (RMAA measurements should easily show if there is a measureable one). I am going to rebuild the power supply for my other amp (which does have a single rectifier and cap bank) and converting to a rectifier and cap bank for each channel, effectively doubling the capacitance and will be taking measurements before and after, however with the speed I get around to things I wouldn't hold your breath waiting for the results Someone else who has actually tried both, listened and measured might chime in Tony. |
#3 |
I haven't measured it, but when I moved from a single rectifier to a separate one for each channel I got a very noticeable improvement in sound quality, and not just the imaging. I also ended up halving the cap bank from 80,000uF for both channels to 40,000uF to each channel because I didn't add capacitance, and did not lose much of the bass.
I went down to 20,000uF per channel later without further loss of impact, whereas with a single rectifier and 40,00uF (my first attempt) the sound was still a little lifeless and would grind down at higher output levels. |
#4 | ||
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#5 | ||
One can always run different analysis and come up with somewhat different numbers, but the finding getting a clean trebel is harder you might think has been a consistent one in my experience. The LME49810 makes better numbers in this regard than any monolithic chipamp I know. If you start looking at biamping or triamping with the tweeter channel as a victim operating the control loop on op amps like the LME49990 or LME49724 ends up being attractive for their higher Avol over the LME49810. Quote:
Another advantage of paired trafos is you can mount them with opposing windings and get some amount of leakage flux cancellation; chipamp circuits tend to be compact enough they're not too susceptible to noise pickup from the trafos but I've seen amps hit surprisingly bad noise problems due to cap charging transients being being reradiated from transformers and picked up within input stages or the feedback loop. Shielding low frequency magnetics is hard, so getting a few extra dB of attenuation from field cancellation is a boon. Last edited by twest820; 6th July 2010 at 05:59 AM. |
#6 | ||
In my case, if using a center-tapped transformer where stereo grounding becomes a real nightmare with just one transformer and two rectifiers. Often the best option is to relocate the star ground to the location where the power supply lead enters the chipamp, decouple it really well with low-ESR caps, and keep the ground paths really short, with a very thick ground wire back to the PSU caps. I still think dual mono is the better configuration. About flux fields - I've used a LM4766 an inch away from a EI-core transformer without any hum being picked up at all. Maybe just lucky, I guess, or maybe not sensitive enough hearing ![]() Quote:
#7 | ||||
#8 |
abraxalito - are you sure about the 56V P-P figure for a chipamp running off say, 34V rails?
#9 |
yes - that's peak to peak. with 34V rails, we have both -34V and +34V so if the amp could swing all the way to the rails we'd get 68V p-p. But it can't, so in practice with 34V rails we get around 62V p-p. 56V p-p is just a conservative figure because in practice we get a little more than 50W into 8R on bursts.
#10 |
Right, I know in theory that's what it should be but I rarely see anything above 14V before the sound starts to crack up real bad. Mostly 11-12V, though most of real listening its 7-8V. I assume these are RMS figures as they come off a DMM. I'm just not sure it can actually manage 20VRMS output cleanly.
| Power Devices for old Power Amplifier's from MOSPEC - Quality Standart like "ON" ? | tiefbassuebertr | Solid State | 4 | 24th February 2011 04:14 PM |
| Can you help me choose capacitors for my amplifier's power supply? | Kuja | Power Supplies | 3 | 12th March 2007 04:03 PM |
| Supply Topology/Grounding for Pre-amp | Bonsai | Solid State | 20 | 2nd February 2007 11:04 AM |
| Power stage topology | frozenpod1 | Class D | 14 | 5th May 2005 04:48 PM |
| Pictures of your amplifier's case | Bricolo | Solid State | 70 | 24th December 2003 09:29 PM |
| Page generated in 0.13924 seconds (83.18% PHP - 16.82% MySQL) with 10 queries |
