Lm3886 grounding made easy(?) - Page 4 - diyAudio
Old 12th July 2010, 06:35 AM   #31
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by pacoblackxx View Post
this is the schematic:
Yep, in my estimation that's wrong, it doesn't follow my recommendations over the rca grounds for a start. But there are others who disagree - so follow whoever you trust the most
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 12th July 2010, 06:39 AM   #32
this is the rca cable that i am using: http://www.e-shop.gr/show_per.phtml?id=PER.750723.
I think that has only one ground cable, that splits on two in the end. So a ground loop between amplifier and the source can't occur..is that correct?
Old 12th July 2010, 02:26 PM   #33
abraxalito's Avatar
No, not correct - as soon as both the white and red rcas are connected to your amp, there's a ground loop.
Here's my suggested topology, wiggly hand drawn lines not to be taken too literally...
Old 12th July 2010, 07:47 PM   #34
Ok thanks!i will give it a try
Old 13th July 2010, 01:42 AM   #35
abraxalito's Avatar
Then when you've listened to this version, change it to the one you had earlier and see if you hear a difference.
Grounding hum on lm3886 kit encode Chip Amps 7 5th May 2008 12:36 AM
Aleph AC current gain made easy darian Pass Labs 8 13th September 2007 05:52 PM
Made a rack - its easy maxw Everything Else 4 23rd February 2005 06:46 AM
Digital X-over made easy. TucsonSean Digital Source 16 25th February 2002 11:15 PM
Copyright 1999-2017 diyAudio
