Lm3886 grounding made easy(?) - Page 2 - diyAudio
Old 8th July 2010, 11:57 AM   #11
Anybody?
Old 8th July 2010, 01:01 PM   #12
post5 links to all the answers.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 8th July 2010, 03:12 PM   #13
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by pacoblackxx View Post
what about my last question?
The answer to that depends on whether those grounds on the pcb were already connected or not. Did you find out for sure?
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 8th July 2010, 09:27 PM   #14
Yeap i checked today.The grounds of the pcb are independent..so?
Old 9th July 2010, 10:24 AM   #15
abraxalito's Avatar
Default Single point grounding sequence
Well the way I'd do it (bearing in mind there are dissenting views here) is have a bolt (say M3) for the chassis connection which is mechanically fixed to the chassis. That takes care of your safety earth because the first tag to go over the bolt is the earth wire from the mains inlet. The next tag is the highest current one - to the power (main-gnd) ground - that's the centre point of your main rail caps. Over that tag goes the speaker ground (spk-out-gnd). Next up is the decoupling ground from your pcb, which I take to be pwr-gnd in your nomenclature. After this I'd have a tag which goes direct to the screen of your input cable - don't bring the screen connection onto the PCB as this ground is noisy with RF. The last ones on are the quietest signal grounds - i.e. pot-gnd and sig-in-gnd. These last two could even be combined together, no real need for separate connections. Then fit an M3 nut and tighten them all down nicely so they lead out in the form of a star.
Old 9th July 2010, 02:36 PM   #16
I have a bolt and nut holding the safety earth to the case (using an earthing lug in the power supply and a ring terminal in the amp case), and then ground wires with ring terminals and an additional nut. That way I can remove the ground wires and the safety earth is always still connected.
Tyler
Old 9th July 2010, 08:36 PM   #17
posts 15 & 16 show the way.
I usually make a version of this.
Safety Earth beside the mains input cable, or IEC socket.
Chassis connection for Grounding the Audio side near the centroid of all the other grounds. This is rarely near the mains Safety Earth.
regards Andrew T.
Old 11th July 2010, 06:01 PM   #18
I cant understand what you mean with the bold sentence. Which is the screen of input cable?
Correct me if i am wrong: the rca-ground goes to the pcb signal-in-ground. The pot ground goes also to the pcb signal-in-ground.then a wire must start from pcb signal-in-ground and then joined with the M3 bolt? Which is the screen of input cable?
Old 11th July 2010, 08:39 PM   #19
a coaxial cable has an inner and an outer.
The outer is the screen.
The inner is the core.
It is usual to send the signal through the core and bring back the return through the screen.
regards Andrew T.
Old 12th July 2010, 01:13 AM   #20
abraxalito's Avatar
I see Andrew has replied to clarify this point.
According to the way I do things, this is wrong. The rca-ground is the same as the screen of the input cable. Don't bring this onto the pcb if you want the best transparency of your amplifier. It carries RF because the cable to your CD player (or whatever source you're using) is an antenna. It also carries hash from the mains back to safety earth because many source components are not grounded nowadays, they tend to be double insulated. So for both of those reasons its sub-optimal to feed all that noise onto your amp pcb.
Yes, you may do it this way - I offered that as an option in my earlier post. The pot ground may be combined with the pcb signal-in-ground and the two of them only need one wire back to the M3 bolt.
Grounding hum on lm3886 kit encode Chip Amps 7 5th May 2008 01:36 AM
Aleph AC current gain made easy darian Pass Labs 8 13th September 2007 06:52 PM
Made a rack - its easy maxw Everything Else 4 23rd February 2005 07:46 AM
Digital X-over made easy. TucsonSean Digital Source 16 26th February 2002 12:15 AM
Copyright 1999-2017 diyAudio
