Lm3886 grounding made easy(?)
Old 12th July 2010, 06:58 AM   #21
pacoblackxx is offline pacoblackxx
so the rca1 ground goes to rca2 ground(with a wire_A), and then i connect the middle of wire_A with the star point. Then i connect pot's ground1 with pcb1 signal-in-ground(wire_B),pot's ground2 with pcb2 signal-in-ground(wire_c), and i connect the middle of wire_B with the star and the middle of wire_C with the star?
what is the difference now?rca ground are coonnected with the star, but also pcb sigal-in-ground are connected with the star. If rca ground has noice(because rca cable is an antenna) that noise will also go to the pcb signal-in-groun from the route: rca-ground->star point->pcb signal-in-ground..
Am i missing something?
Old 12th July 2010, 07:03 AM   #22
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I have no idea what rca1 and rca2 are referring to here.
Likewise no clue as to how a pot can have grounds 1 and 2, nor which pcb1 and pcb2 are. Please clarify.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 12th July 2010, 07:12 AM   #23
a female rca socket has two 'pins'.one for the signal and one for the ground. I mean rca socket' ground pin. i have this rca socket: http://www.traderscity.com/board/use...k-socket-1.jpg.
there also two types of pot:
3 pin:http://img.alibaba.com/photo/2927828...-15mm.summ.jpg
and 6 pin:http://myweb.tiscali.co.uk/nuukspot/decdun/gc/pot1.jpg
The 6 pin has 2 grounds!
Old 12th July 2010, 07:19 AM   #24
can you correct this shcematic acocording to what you are saying?
http://img718.imageshack.us/img718/8347/ok2h.jpg
its the topology of "understanding star ground" thread.[post5]
http://www.diyaudio.com/forums/chip-...grounding.html
Old 12th July 2010, 07:20 AM   #25
abraxalito's Avatar
Still confused. You can't mean that rca1 = rca socket ground pin and rca2 = rca socket signal pin because you're suggesting to short rca1 and rca2 together. So are you meaning left channel rca by 'rca1' and right channel rca by 'rca2' ?
Yeah, those pics show stereo pots. So one group of 3 pins is for left, the other for right. You need to connect the left channel pot ground only to the left channel pcb, and the right channel pot ground only to the right channel pcb.
Old 12th July 2010, 07:23 AM   #26
abraxalito's Avatar
No, it looks like that website is blocked by the great firewall of China and I don't have my VPN set up on this machine.
Old 12th July 2010, 07:24 AM   #27
look me last post if you can.
yeah rca1 is the left channel(and has ground1) and rca2(which has ground2) is the right! you said to connect ground1 with ground2 and then use a wire to the star ground.
according to post4 of "undersanding star grounding" if you trie to connect pot ground to pcb signal-in-ground for both the pots you have a ground loop..
Old 12th July 2010, 07:29 AM   #28
this is the schematic:
Old 12th July 2010, 07:31 AM   #29
abraxalito's Avatar
Some ground loops are unavoidable in a stereo amplifier. Both left and right channels share the same ground at the source, then there are two cables run in parallel (your left and right channels) which are then connected together at the amp end. The left-gnd and right-gnd are going to be in a loop, its unavoidable unless we go for full mono-block construction with separate supplies for left and right. Ground loops are only a worry if there's something pushing current around in them - in these cases its fairly insignificant.
If you're wanting the ultimate sound quality (which is what I'm working on) then balanced interconnections are the only way to go. The professionals have been working this way for years, seems domestic hifi is stuck in the dark ages
Old 12th July 2010, 07:34 AM   #30
can you correct the diagram above? keep in mind than pcb signal-in-ground and pcb signal-out-ground are separeted on pcb, that's why i cant use the schematic posted on "understanding star grounding" [post5].
Lm3886 grounding made easy(?)Hide this!Advertise here!
Grounding hum on lm3886 kit encode Chip Amps 7 5th May 2008 01:36 AM
Aleph AC current gain made easy darian Pass Labs 8 13th September 2007 06:52 PM
Made a rack - its easy maxw Everything Else 4 23rd February 2005 07:46 AM
Digital X-over made easy. TucsonSean Digital Source 16 26th February 2002 12:15 AM
Copyright ©1999-2017 diyAudio
