Combining one set of amp controls to control two amps?
Old 25th June 2010, 04:47 PM   #1
DICEPD is offline DICEPD
Smile Combining one set of amp controls to control two amps?
Hey guys,
I recently purchased two Rockford Fosgate P200.2 amplifier circuit boards to power my PA speakers.
I run the 12v amplifiers off a AC/DC inverter 15v/60a and plan on combining the amplifiers into one box, I have some extra amplifier heatsinks and four 12v fans to help with heat dissipation.
Here is a pic of one of the amps
I assume I can just undo the solder on the controls of one amp and wire some into the other one? If anyone has some thoughts please advise
Old 25th June 2010, 11:43 PM   #2
irishlyrucked is offline irishlyrucked  United States
i'm assuming you meant the potentiometers. If so, you would not want to combine them on to one potentiometer unless you replaced two single pots with a dual pot.
Old 26th June 2010, 12:03 AM   #3
What do you mean the pots?
Old 26th June 2010, 05:54 PM   #4
Minion is offline Minion  Canada
Pots are Potentiometers ,you know , the things you turn you controll the Volume , tone ect ?
Old 26th June 2010, 07:44 PM   #5
Yeah I understand that, I mean what is a dual pot? I assume two separate inputs but separated completely and the same knob controls the two circuits?
Old 27th June 2010, 03:38 PM   #6
a dual pot is basically two potentiometers that are controlled by one knob.
Old 27th June 2010, 05:53 PM   #7
Th3 uN1Qu3 is offline Th3 uN1Qu3  Romania
Send a message via Yahoo to Th3 uN1Qu3
Dual pots are what you want. Also make sure you get logarithmic (log) pots otherwise with a linear pot the volume will be low for 80% of the pot travel then increase rapidly, something which you don't want.
Old 28th June 2010, 10:07 PM   #8
firechief is offline firechief  United States
firechief's Avatar
Wow - what is up with those little boards that are attached to the output devices? So those get removed and the transistors attached to the heatsink? I have a hard time beliving that they would make an acceptable heat transfer medium. Are these surpluss boards? where did you get them.
Intresting plan, keep us informed
Combining one set of amp controls to control two amps?Hide this!Advertise here!
2 amps, 1 set of speakers boostin1989 Solid State 3 24th May 2010 09:40 PM
2 amps with 1 set of speakers? webelo Tubes / Valves 27 29th August 2009 12:49 PM
reducing hum in SET amps pjpoes Tubes / Valves 8 2nd May 2007 12:32 AM
Dividing power between different speakers from single source & Combining channels Fusion-One Parts 0 10th April 2007 01:18 AM
I want to set up a digital control voltage supply xiaonan Power Supplies 11 7th September 2006 08:31 AM
