| Chip Amps Amplifiers based on integrated circuits |
Howdy,
I recently built a few amps using TDA7240 ICs. I used the circuit design from the spec sheet. They seem to work pretty well, but for some reason, when set to a very low volume, there is an audible "scratchiness" to the music. Any ideas what would cause this? I did not use shielded wires to connect the source (iPod) to the amp input. Is this the likely culprit? I'm doubting it's the volume potentiometer itself, but I'm no expert. here's a schematic of the circuit if you'd like to take a peek: http://circuits.datasheetdir.com/344...40A-pinout.jpg Thanks for all the help! |
#2 |
haha, its a old thread. I'm also building this chip amplifier X.x
Of course using shielded wire helps, but the noise is at same volume at all condition. The "scratchiness" you mention, is it variable as the volume of music ? or same all the time ? |
#3 |
Did you put local decoupling caps near the supply pins ( minimum 1000 µF ) ?
#4 |
Local decoupling suggested by most manufacturers never approaches 1000uF (1mF).
Why should the 7240 be different?
regards Andrew T. |
#5 |
Sorry , I read '7294'....
#6 |
sorry ,I also read '7294'...
| Help with a TDA7240 based amp | giralfino | Chip Amps | 8 | 9th May 2010 02:17 PM |
| fosgate punch 400a4 get hot at low volumes | chipper | Car Audio | 3 | 26th September 2009 05:05 PM |
| Driver for low volumes | TechnoMage | Subwoofers | 15 | 7th October 2006 10:41 AM |
| Does Pass D1 roll off treble at low volumes? | kiwi_abroad | Pass Labs | 1 | 17th September 2006 10:53 AM |
| How important is sensitivity for near field at low volumes? | bluegti | Full Range | 8 | 13th January 2006 04:55 PM |
| Page generated in 0.07593 seconds (82.17% PHP - 17.83% MySQL) with 10 queries |
