LM3886 issues - Page 2 - diyAudio
Old 22nd June 2010, 11:37 PM   #11
4.4 might be it lol. Sorry I'm terrible at reading resistors. Gold gold black red I think is the combo. Actually final color might be brown.
Old 22nd June 2010, 11:47 PM   #12
red = 2 or brown = 1
black = 0
gold = divide by 10
gold = 5%
red black gold gold = 2r0 +-5% non standard value from e24 range
brn blk g g = 1r0 +-5%, more likely since this is an e6 and e12 value.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd June 2010, 12:57 AM   #13
This may be a silly question but is there a bridge rectifier that I may be able to find locally at say radio shack or something?
And yes I read backwards so 2ohms....
I'm gonna run over to my wifes grandmothers and grab my DMM. I'll try testing between those points.
Old 23rd June 2010, 01:38 AM   #14
Ok, checked with a DMM between the +/- to the ground and they do in fact fill. I held it there until about 10k ohms. So that looks ok. Would be nice if I could find some rectifiers locally though. Guessing rat shack doesn't really have anything though.
Old 23rd June 2010, 01:48 AM   #15
infinia is offline infinia  United States
infinia's Avatar
RadioShack® 8A/400V Full-Wave Bridge Rectifiers - RadioShack.com
Not the best for the bucks but a local source.
As others pointed out> ditch the connectors and solder both bridge rectifiers!
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 23rd June 2010, 01:57 AM   #16
Ok thanks! I'll try and grab some tomorrow. I'll definitely solder them. Would it be a bad idea if I just replace the one with that style? Or should I do them both?
Old 23rd June 2010, 02:02 AM   #17
infinia's Avatar
I would do them one at a time and test between mods. Screw them down no more glue of course.
Old 23rd June 2010, 02:04 AM   #18
Well it's not my amp, just repairing it so have to see if he wants me to screw them down. Like I said I didn't build it lol I would of done it differently.
Old 23rd June 2010, 05:34 AM   #19
Arx is offline Arx  Canada
just disconnect the rectifier and test it. It's just 4 diodes. check wikipedia if you need to know which way they go.
Test with your meter set to the diode check, and see what the voltage is across each diode. if they read 0 or you get no reading, then it's fried. If you get a reasonable drop for all 4 diodes, you probably need to look elsewhere.
I wouldn't be surprised if it's just a bad connection. Usually things like that are soldered, and there could easily be enough current to cook the contacts on those connectors.
Old 23rd June 2010, 09:23 AM   #20
I don't doubt there could have been a bad connection, but I don't see how it would make it heat up hot enough to spread the high temp hot glue all over the place. I'll check it out in a bit when I get back from taking the wife to work.
LME49810/11/30, LM3886 hum issues & grounding tomchr Chip Amps 10 22nd February 2010 10:18 PM
PA100 Heat Issues...LM3886 Based..Any Ideas? Travis Clarke Chip Amps 10 16th December 2007 11:18 PM
LM4780 (LM3886) impedance issues Alfetta87 Chip Amps 1 21st November 2006 02:35 PM
LM3886 & PGA2310 issues Xlrator Chip Amps 0 7th March 2006 07:25 AM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
Copyright ©1999-2017 diyAudio
