| Chip Amps Amplifiers based on integrated circuits |
Is there an advantage of either one over the other for this?
Thx, Rob |
#2 |
a well made switched pot has much closer matching of channels than a pair of tracks inside a dual pot.
The switched pot may be more reliable and certainly easier to keep clean. The switched pot is generally more expensive and sometimes as much as 200times more. The switched pot would need a much stronger motor if you decided to go for motor adjustment.
regards Andrew T. |
#3 |
Thx. Don't need motor ctrl. One concern I have with switched POTs is that the make-break of contacts, as you rotate knob, could cause pops and clicks in the audio. Anyone see (hear) this happen?
#4 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I built one with reed relays, it certainly did happen. I believe you can get make before break switches which will certainly help but not totally eliminate clicks.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
#5 |
if you ensure that there is no DC voltage across the switch then make before break should lead to silent switching.
How often do you adjust volume, once per track, once per hour, once per listening session?
regards Andrew T. |
| Switched Pot Source Needed | Trout | Tubes / Valves | 1 | 9th June 2006 01:42 PM |
| Tone ctrl bypass reduces volume? | DragonMaster | Solid State | 17 | 9th September 2005 02:10 AM |
| New JFET switched volume control | MBK | Solid State | 14 | 6th April 2004 06:56 PM |
| Digital relay switched log pot emulation audio .WAV's. | Brian Guralnick | Pass Labs | 1 | 8th October 2003 05:39 PM |
| Page generated in 0.09408 seconds (80.71% PHP - 19.29% MySQL) with 10 queries |
