How to connect a potentiometer
Old 17th June 2010, 02:27 PM   #1
giralfino is offline giralfino  Italy
giralfino's Avatar
Default How to connect a potentiometer
Hi all,
I'm building a mono chip amp based on TDA7240A and want to add a potentiometer as a volume control. I have in house a 20K stereo log pot that I could use since it is of good quality. My problem is how to identify the three contact I should use (in from source, out to amp, ground), from the six that there are on the pot.
Thanks,
Ralf
Old 17th June 2010, 03:04 PM   #2
firechief is offline firechief  United States
firechief's Avatar
Potentiometers (Beginners' Guide to Pots)
Here is all of the information you need.
Sounds like you have a dual pot. That could be handy
Old 22nd June 2010, 12:41 PM   #3
giralfino's Avatar
Unfortunately the article doesn't solve my problem.
I should explain better the situation: I have a pot with 6 terminals in a row, they are not marked in any way, so I can't figure what are the three terminals I have to connect (in , out, ground).
Is there a way with a simple ohm meter to find the correct ones?
Thanks,
Ralf
Old 22nd June 2010, 02:24 PM   #4
sregor is offline sregor  United States
Shouldn't be that hard. Turn the pot counter clockwise - volume all the way down. 2 pairs of contacts should read zero ohms to each other. The other two contacts should read 20k ohms to one of the first set of contacts. These two would be the high side. Then turn the volume all the way up - clockwise. The 20k ohms taps previously determined will read zero ohms to one of the other taps. This tap will be your wiper. The last tap would be the low side. High side = in Lowside = ground Wiper = out. Good luck with it.
Steve
Old 22nd June 2010, 03:49 PM   #5
firechief's Avatar
A pot with six terminals in one row is a very strange animal. I was thinking it was two rows of three terminals. in any case sregor is describing a valid technique. If all else fails, a picture Im sure would make a big difference.
Old 22nd June 2010, 04:55 PM   #6
Mooly's Avatar
Seen some odd ones before, five terminal ones.
RK14J12R0A01 datasheet pdf datenblatt - ALPS ELECTRIC CO.,LTD. - With Knob Type ::: ALLDATASHEET :::
Old 24th June 2010, 06:24 PM   #7
giralfino's Avatar
For your curiosity I attach a photo of the pot, it was used as a volume control in a Philips mini system.
I think I have found the right contacts: pins 2,3,5 from the right.
At zero volume, pins 3-5 is 0 Ohm, 2-3 and 2-5 is 20K Ohm, while at maximum volume pins 2-3 is 0 Ohm, and 2-5 and 3-5 is 20K Ohm.
Thank you all
Ralf
Old 24th June 2010, 06:31 PM   #8
Mooly's Avatar
Thanks for posting the picture... I'd forgotten many all in ones have motorised VC's... and I've worked on enough over the years.
Thanks.
How to connect a potentiometerHide this!Advertise here!
How do I connect drclean Solid State 0 15th December 2008 06:03 PM
Potentiometer SergeDufour Vendor's Bazaar 0 12th December 2006 08:30 AM
How to connect a sub??? Klimon Subwoofers 6 19th June 2006 03:18 PM
Looking for potentiometer paulc Class D 6 3rd February 2006 11:57 PM
Copyright ©1999-2017 diyAudio
