The best preamp. ???
Old 15th June 2010, 10:19 PM   #1
PROFESSOUR2003 is offline PROFESSOUR2003
Default The best preamp. ???
Hi
i was woundering what is the best preamp for tda7294 in bridge mode..??
Old 17th June 2010, 06:41 AM   #2
diptangshu is offline diptangshu  India
diptangshu's Avatar
Send a message via Yahoo to diptangshu
please specify what is the input type for that preamp?
Old 17th June 2010, 08:53 AM   #3
gmphadte is offline gmphadte  India
There r many 5532 audio ckts on the net.
For a 7294 a 5532 is good enough. In fact it sounds really good. Phillips make sounds the best.
Gajanan Phadte
Old 17th June 2010, 08:59 AM   #4
diptangshu's Avatar
Originally Posted by PROFESSOUR2003 View Post
Hi
you may use LF353 preamp. If you want I can give you all schem.. and PCB..
That is tested and got nice result.
Old 17th June 2010, 09:07 AM   #5
R.I.P.
why do you need a preamp?
A bridged output amplifier normally has twice the gain of an unbridged amplifier. This usually results in requiring more attenuation of the input signal.
regards Andrew T.
Old 17th June 2010, 11:09 AM   #6
hi
my input is usually my mobile phone. and what about tda1524a as atone control circuit it`s phillips too.and i was woundering if i can put two modules of bridged tda7294 in parallel .!!? if it is possible how can i do this ??
AT LAST THNX 4 ALLLLL
Old 18th June 2010, 08:48 AM   #7
diptangshu's Avatar
hi
As per my opinion you dont needany more preamp for this project. If you feel you really need a preamp, can mail me. diptangshu@gmail.com
Old 18th June 2010, 11:45 AM   #8
ok i will do thnx soo much.
The best preamp. ???Hide this!Advertise here!
Running a tube preamp into a solid state preamp? Pckid212 Solid State 5 6th January 2013 10:12 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
