Tda7294 again .!!
Tda7294 again .!!
Old 14th June 2010, 10:12 PM   #1
PROFESSOUR2003 is offline PROFESSOUR2003
Question Tda7294 again .!!
HI,
I intend to build this circuit for my stereo amp. each channel will consist of 2 tda7294 in bridge mode all i need is pretty pcb for this circuit-or i`ll have to build it on general purpose board..lool- & any one have any comment or modification about the circuit i am glad to hear it...
I will use 24-0-24 10 amp. transformer
2 * 8 ohm speakers
and this circuit for tone control
THNX,,,,
Old 15th June 2010, 11:19 AM   #2
32 views and 0 reply ...!!??
Old 28th June 2010, 07:43 AM   #3
adil is offline adil  Pakistan
good amp
Old 28th June 2010, 01:09 PM   #4
sangram is offline sangram  India
24 Volt transformers will result in rails of about 33-35V depending on mains voltage. You risk frying the chips with that voltage and that load. For 25V rails I would use 18 or 19V transformer.
Using a single resistor to bridge the chips will work, but I don't know that it is ideal in terms of performance. It might be worthwhile to explore a dedicated balanced line driver chip or use the second amplifier in inverting mode with a few suitable modifications in the gain resistors.
Good Luck.
Old 28th June 2010, 01:50 PM   #5
riktw is offline riktw  Netherlands
use a 18V transformer, better for the chip :P
and design a neat PCB for it, a good amp deserves it imho
but TDA7294 amplifiers are very good, i personally like them more then the normal lm3886.
but for power supply, a good 2 * 18V transformer, 225VA per channel, and 20.000uF per channel for capasitors.
now build it and be amazed
Old 28th June 2010, 08:18 PM   #6
i have successfully built it and i will upload photos as soon as possible
THNX
Old 31st January 2011, 02:06 PM   #7
Hosam is offline Hosam  Syria
I just have question about the power supply, does 2x22v transformer will effect the chip as sangram mention above?
I want to build two PCB one single TDA and the other one is bridge 2xTDA. if I want to use power supply for both is it good to keep each one with own power supply or its better to use power supply for both "bridge and single TDA's"?
Old 2nd February 2011, 10:10 PM   #8
nikko is offline nikko  Bosnia and Herzegovina
View from the APEX you have finished the project.
TDA7294 Stereo/Bridge with PSU
Greeting
Old 2nd February 2011, 11:07 PM   #9
ianpengelly is offline ianpengelly  United Kingdom
ianpengelly's Avatar
According to the datasheet in the bridge configuration +/- 35V rails is more than acceptable and offers upto 170W output. The max permissable is +/- 40V, so there is no worry of frying this chip with the transformer suggested. What did you use in the end PROFESSOUR2003?
Are you pleased with the results?
Tda7294 again .!!Hide this!Advertise here!
Tda7294 e_fortier Chip Amps 2 27th November 2008 02:33 PM
TDA7294. . . help! ;) danielwritesbac Chip Amps 3 19th April 2008 07:58 AM
Tda7294 Angel Puerto Chip Amps 6 21st August 2003 03:08 PM
Copyright ©1999-2017 diyAudio
