tabs touching, no output
Old 3rd July 2003, 01:26 PM   #31
moamps is offline moamps  Croatia
Originally posted by Matttcattt
i know this should be true, but both chips tabs are at 0.3v from ground.
Disconnect amp from power, discharge and desolder PS caps from chip, then measure resistance between "3,4" and tab. If isn't close to zero, than chips are faulty (or apps note is faulty ?!).
Old 4th July 2003, 10:07 AM   #32
Matttcattt is offline Matttcattt  England
Matttcattt's Avatar
i was trying to measure some resistors with my multimeter and was getting no reading, i found that one of my test leads was broken. i have re-tested the tabs with a new set of (working) test probes, and they are both at -15v as they should be. strangly, both amps still work when the tabs are connected. maybe when i noticed that they didnt work when the tabs were connected was a freak incedent.
sorry to waste your time.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 6th July 2003, 01:41 AM   #33
travis is offline travis
Send a message via AIM to travis
wait, can i mount two chips to the heatsink or not? if i use one set of filter caps?
donuts
tabs touching, no outputHide this!Advertise here!
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Soldering Binding Posts - Solder Tabs disconnec Multi-Way 5 20th September 2005 02:28 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Copyright ©1999-2017 diyAudio
