tabs touching, no output - Page 3 - diyAudio
Old 2nd July 2003, 07:02 PM   #21
Matttcattt's Avatar
Originally posted by tiroth
Is the tab voltage 0.3V for both units when disconnected?
You should list the separate disconnected voltages as well as the common connected voltage.
yes, this is the reading from both chips, when they are disconnected. i will see what the voltage it when they are connected.
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 2nd July 2003, 08:37 PM   #22
moamps is offline moamps  Croatia
tab (heatsink) voltage on plastic package must be -Ve, metal TO3 is isolated; N.C. What voltage is between two noelectrically connected heatsinks?
Old 2nd July 2003, 09:14 PM   #23
Matttcattt's Avatar
both tabs (heatsink) (plastic package) are at 0.3v with the common lead of my multimeter connected to star ground. i do not understand your question. they are both at approx. 0.3v so, no more than 0.1v difference between the heatsinks. have i understood your question correctly?
Old 2nd July 2003, 09:41 PM   #24
What voltage is between pins 3,4 and tab?
What voltage is between 3,4 and stargnd?
Old 2nd July 2003, 09:43 PM   #25
Matttcattt's Avatar
i cant measure at the moment, but i guess:
A) -14.7v
B) -15v
Old 2nd July 2003, 09:59 PM   #26
A) -14.7v
B) -15v
Strange, according to apps note (A) voltage must be zero....
Old 2nd July 2003, 10:40 PM   #27
Matttcattt's Avatar
it should be -15v accrording to the datasheet. the amplifier uses dual power supplies. +/-15v.
Old 2nd July 2003, 11:28 PM   #28
Account Disabled
that is because both are at -Vdc?
Old 3rd July 2003, 11:33 AM   #29
Yes,
good readings between some points for PS+/-15V are:
"3,4" - gnd ......-15V
"10,11" - gnd ......+15V
"3,4" - tab ......0V
tab - gnd ......-15V
"10,11" - "3,4" ..... 30V
If IC is directly mounted to the heatsink, then the heatsink must be electrically isolated from all parts inside the chassis and from the chassis itself (if the chassis is metal).
Old 3rd July 2003, 01:39 PM   #30
Matttcattt's Avatar
Yes,
i know this should be true, but both chips tabs are at 0.3v from ground. also, i know that the chips and heatsink should be insulated, and it will be, but i wish to know why the tabs are at 0.3v, and why the two chips will not work when the tabs are electronoically connected.
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 11:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 07:15 PM
Soldering Binding Posts - Solder Tabs disconnec Multi-Way 5 20th September 2005 03:28 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 01:57 PM
Copyright 1999-2017 diyAudio
