tabs touching, no output - Page 2 - diyAudio
Old 26th June 2003, 03:32 PM   #11
Matttcattt's Avatar
is anyone else going to comment? or should i just forget this and just insulate the chips from the heatsink?
If it aint broke, don't fix it. If it is broke, fix it.
If you can't fix it, take it apart and see how it "worked".
Old 26th June 2003, 03:53 PM   #12
zobsky is offline zobsky  India
zobsky's Avatar
hi,
i belive that insulation using a thin mica insulator was the recommended method on some of the diy-gainclone guides
cheers
Old 26th June 2003, 04:09 PM   #13
JOE DIRT®'s Avatar
are using thermal grease on the tabs???....also have you disconnected the -v hook up wires???.....and tell me the heatsinks are isolated from the chassis
DIRT®
Old 26th June 2003, 05:32 PM   #14
Matttcattt's Avatar
yes
no
i havent got a chassis yet, i just tried connecting the heatsinks together
Old 26th June 2003, 06:47 PM   #15
JOE DIRT®'s Avatar
maybe the thermal compound is causing enough of a resistance.....also another Q.....is each channel on the same power supply???
Old 26th June 2003, 06:57 PM   #16
Matttcattt's Avatar
yes
but i want to know why they wont work with the tabs connected.
Old 26th June 2003, 07:32 PM   #17
JOE DIRT®'s Avatar
my last kick at the cat Matt...and I may be wrong here...but some manufacturers do connect a power IC substrate to the mating surface and although it is a common connection it wont conduct enough...they refrain you from using a heatsink for a common connection because they know of possible isolation problems
until you tell us some voltage readings and what testing you have have done I`m kinda stuck about your problem as I have not read the data sheet or am familiar with the chip you are using.....but I`m sure one of the audio pro`s here will have a better clue
DIRT®
Old 26th June 2003, 08:33 PM   #18
Matttcattt's Avatar
DIRT®
ok, ill read the voltages when i get a chance.
Old 2nd July 2003, 02:38 PM   #19
Matttcattt's Avatar
i have mesured the tabs, from ground. they are at 0.3v from ground. not -15v as they should be...
Old 2nd July 2003, 04:09 PM   #20
tiroth is offline tiroth  United States
Is the tab voltage 0.3V for both units when disconnected?
You should list the separate disconnected voltages as well as the common connected voltage.
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Soldering Binding Posts - Solder Tabs disconnec Multi-Way 5 20th September 2005 02:28 AM
I2S digital output in Marantz CD4000 and four TDA1541A with balance analog output iklari14 Digital Source 30 18th July 2003 12:57 PM
Copyright ©1999-2017 diyAudio
