| Chip Amps Amplifiers based on integrated circuits |
I've read so many good things about this opamp, yet given it is so fussy, no-one seems to have designed an amplifier based solely around it.
Has anyone seen a decent circuit using this chip? |
#2 |
Here is the product page, at analog.com:
AD843 | 34 MHz, CBFET Fast Settling Op Amp | Military/Aerospace | Other Products | Analog Devices Here is the datasheet: http://www.analog.com/static/importe...eets/AD843.pdf Maybe it's a little too "hot" for typical audio circuits, with its 10 ns rise time and 250 V/us slew rate. But I see no overriding reason that you couldn't try it, at least just to see what happens, if you pay some attention to the datasheet's circuit recommendations. |
#3 | |
You need good grounds and stiff power supplies when dealing in high speed. It's generally 'safer' to run somewhat lower impedances with high speed amplifiers. Feedback resistors in the 1-10K range rather than 30-50K. Ground plane PCBs are preferred rather than a ground 'trunk' snaking its way around the board. There are opamps a little better tailored for audio than the 843 but by all means try it. It certainly isn't bad but then again I AM biased towards Analog Devices products. G² |
#4 |
#5 |
Is such high bandwidth ever required for audio applications? Surely an audio specific op-amp (AD797, LM4562, even OPA2134) will give better performance in audio applications? The audio specific design of these op-amps gives them lower noise and THD whilst maintaining plenty adequate bandwidth.
| FS: Millett Hybrid headphone amp / pre-amp and Tube power amplifier | BuzzerBro | Swap Meet | 7 | 22nd June 2010 08:51 PM |
| HLLY HIGH END DMK-IV USB DAC Headphone AMP Pre-AMP | hllyelec | Vendor's Bazaar | 19 | 4th January 2010 01:10 AM |
| Silicon Chip July06 / EPE Feb08 Studio Series Pre-Amp with remote and Headphone Amp | pgamble | Headphone Systems | 6 | 8th November 2009 09:50 AM |
| NE5532 as a pre amp for a Szekeres headphone amp | zebra100 | Headphone Systems | 2 | 1st July 2009 09:15 AM |
| need a PS for a pre, DAC, and headphone amp | fishski13 | Power Supplies | 6 | 12th February 2009 06:59 PM |
| Page generated in 0.07735 seconds (77.28% PHP - 22.72% MySQL) with 10 queries |
