about HIP4081,need help
Old 12th June 2010, 05:49 AM   #1
handsomeuu is offline handsomeuu  China
Post about HIP4081,need help
I got a demo board of NuForce Amplifier a couple of days ago and i found that the resistance connect to the pin HDEL ,which belongs to HIP4081, had a value of 200 Ohm . But according to the datasheet, it is supposed to has a value between 10K Ohm to 200K Ohm. I don't know why, i need some help.
P.S The demo board is working in a good condition.
Old 14th June 2010, 09:12 PM   #2
gfiandy is offline gfiandy  United Kingdom
gfiandy's Avatar
This pin is controlled by the current from it to ground. If the 200R is connected to another circuit that controls the current, this could explain why the value is so low.
If it is working I would not change it unless you have determined exactly what is going on and understand what you are doing. The resistor controls the comutation delay and if you mess it up you are likely to damage the chip.
Andrew
Old 21st June 2010, 02:22 AM   #3
Originally Posted by gfiandy View Post
this pin is controlled by the current from it to ground. If the 200r is connected to another circuit that controls the current, this could explain why the value is so low.
If it is working i would not change it unless you have determined exactly what is going on and understand what you are doing. The resistor controls the comutation delay and if you mess it up you are likely to damage the chip.
andrew
thx
about HIP4081,need helpHide this!Advertise here!
Stereo Class-D amp HIP4081 Whortless Class D 59 2nd February 2014 03:15 AM
Copyright ©1999-2017 diyAudio
