X-Amp (LME49830 + Exicon Lateral Mosfets) - Page 3 - diyAudio
Old 25th June 2011, 09:18 PM   #21
danfo098's Avatar
I've assembled two amplifiers now but I haven't powered them yet. First I need to figure out how much quiescent current I should bias the MOSFET's with and appropriate resistor values (R7 and R8). I'm thinking 40-50 mA per pair @ +- 60V.
Here are some pictures of the current progress.
Old 27th June 2011, 07:47 AM   #22
qusp is offline qusp  Australia
qusp's Avatar
yeah, well its definitely looking good. just confirming my interest and when you are happy with the design. please let me know.
cheers
Jeremy
Old 27th June 2011, 10:31 PM   #23
danfo098's Avatar
So I soldered on a 2k pot where R7 is supposed to go to find an appropriate value(s) for the biasing resistor(s). I preadjusted the pot to 300R which I figured would be safe (0.002*300=0.6V) and just to be extra safe I set the lab supplies current limit to 150mA/rail. I started turning the pot slowly and nothing happens and so I turn some more and nothing, I then measure the voltage across the pot to find it to be 2V and still nothing, no increase in current consumption and no voltage across the source resistors.
Hmm.. the voltage between POut and NOut is 2V and so the MOSFET's should start to turn on right.. after some headscratching I measure the voltages on the N-channel gates relative to ground to find them to be -1V and of course the voltages on the P-channel gates are +1V... curses!
So I managed to mix up pin 13 and 14 on the LME chip schematic symbol, I guess I was thinking POut - positive rail and NOut - negative rail not POut - P-channel and NOut - N-channel as I should have been...
Desoldering pin 13 and 14 and switching them around was pretty easy though. Luckily the mixed up pins are next to each other it would have been uglier if they were on opposite sides of the chip.
With the pins soldered in the correct places I got 45mA per pair with the pot set to 510R so no need to use R8 (the purpose of R8 is to be able to fine tune the quiescent current by parallelling two resistors to get a wider range of possible values).
Anyways the amp has been playing for a couple of hours now and I'm quite impressed it sounds pretty good.
Old 28th June 2011, 12:34 AM   #24
danfo098's Avatar
Made some videos.
YouTube X-Amp playlist
Old 28th June 2011, 03:30 AM   #25
stoc005 is offline stoc005  United States
stoc005's Avatar
Default Source for those lateral FETS in USA
You can buy the identical lateral fets form Newark and they are in stock.
Part number is ALF16N20W and ALF16P20W. They are from Semelab. Datasheet is identical to the ECW20N20, ECW20P20. You can get TO-3 packages if you are into metal.....
BTW, there is NO gate protection on these devices. Read the data sheet. I'd recommend using 12V zeners for G-S over voltage protection. But I see you have some 8.2V zeners.....
Anybody have Spice models??? I have some that "work" in LTSpice but since I created them I'd rather have the real things.
The 20A (or 16A as called by Semelab) devices I believe have 2 dies in parallel inside each TO-264, based on the power dissipation doubling as the device goes from 10A to 20A. Also, the input (G-S) capacitance is almost double of the 10A device.
Old 28th December 2012, 10:26 PM   #26
DIGORA is offline DIGORA  Belgium
HI
The LME49830 could be used with 4 pushpull of 2SK1058/2SJ162 without driver ?
Old 29th December 2012, 10:10 AM   #27
svon is offline svon  Israel
I do not think this is the best design.No electrolytic power capacitors
Old 31st December 2012, 12:56 AM   #28
panson_hk's Avatar
I prefer to add driver to deal with gate capacitance.
Old 14th October 2013, 04:05 AM   #29
I think so as there is 500pf of gate capacitance but how is the sonic signature of the above amplifier?
Counterpoint SA-100 with Exicon MOSFETs woodman Solid State 28 23rd March 2014 02:25 PM
2A ClassA using EXICON Lateral lineup Solid State 4 31st January 2009 11:32 PM
How do the pinouts on Exicon mosfets work? reiver Solid State 4 11th October 2008 01:27 AM
Lateral mosfets - why ? Stormo Solid State 5 2nd July 2003 07:14 AM
exicon mosfets STUART Solid State 8 23rd November 2001 09:30 PM
Copyright ©1999-2017 diyAudio
