If TDA7294 Can work in 30V AC transformer - Page 2 - diyAudio
Old 16th May 2012, 11:39 PM   #11
Minion is offline Minion  Canada
Stuff like that happens when you only read the first 3 words of a datasheet .....
if you read further you would see that it is only +/-50v with "No signal" .....
It actually only has an operating range of a max of +/-40v though I have used them at +/-42v(tda7293) .....
Old 17th May 2012, 05:42 AM   #12
guaxian is offline guaxian  China
Send a message via Yahoo to guaxian
7294working fine in 42v DC for a year. thanks all!
Old 17th May 2012, 03:39 PM   #13
masood is offline masood  India
Originally Posted by vedmitraa View Post
Hi everybody, This is Vedmitrasharma from City of Tajmahal . Can somebody guide me how to parrellel T D A 7294 I.C.s to get more current power to drive subwoofers as the have done with L M 3886 in Berringer moniter box with 3 I.C.s .regards everybody .waiting for reply
dear vedmitra namaskaar,
do you have got this 3 ic pcb and from where you got these ics.plz send me the pcb image of three ic's.thanks a lot
Old 17th May 2012, 10:36 PM   #14
danielwritesbac's Avatar
Here's four attractive ways to get rid of some extra voltage:
1
You could try Fairchild Stealth as a bridge rectifier. This will give the slight voltage drop and good results.
or
2
Alternatively, you could use an ordinary bridge rectifier and make a CRC type power supply, whereby "R" = D-D-D//R. That is one fairchild stealth (~2v) or three series ordinary diodes limiting the voltage drop of one resistor to 0.7v*3, about 2.1v. The value of "R" will be quite high so as to allow the voltage drop. It looks just like sticking a 2v diode parallel to the R in a CRC.
or
3
For a more orthodox approach, you could use an ordinary bridge rectifier, like KBPC1610 or KBPC1010 with 1 of 4.7nF parallel with each diode, an RC parallel with transformer secondaries, one or several MOV's for transformer primary. . . and also construct an ordinary crc type power supply for a bit cleaner DC. Perhaps a lot of noise removal can drop the extra 2v.
or
4
Last, but not least, any time there's a chip amplifier and too much voltage, you have a wonderful opportunity to improve quality by using a regulator, such as documented here: Chip amp with a regulated power supply (PSU). (like most normal amplifiers, TDA7293/4 will differ from that gainclone example by needing additional 220uF or 330uF added for v+ and v- directly at the chip power pins).
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 17th May 2012, 10:37 PM   #15
Didn't realise the thread was this old
Stressing the manual says it is a 100V chip doesn't change the fact it is specced as being a +/-40V chip and running it at 42V increases the power it has to dissipate, and therefor decreases the power available for music reproduction.
But the chip should handle the voltage without problems imho. But at the expense of more useless powerdissipation and therefor possibly less poweroutput. And for this reason it would also be madness to feed it with 40V for a 4 ohm load...
Farnell Transformer- cheap 300VA 2*30V Andrew Milling Power Supplies 0 7th April 2010 09:31 AM
FS: Avel 625VA 30V+30V Transformer mfb Swap Meet 1 12th July 2007 06:59 PM
What to do with two 30V,50A transformer??? Leolabs Solid State 28 26th May 2007 02:49 PM
UK: transformer 2 x 30V @ 2A bigbrowncow Vendor's Bazaar 1 20th February 2007 09:34 PM
Help...TDA7294 bridged can't work yikchean Chip Amps 5 3rd December 2006 04:06 PM
Copyright 1999-2017 diyAudio
