Old 10th April 2012, 07:33 PM   #951
Thank you. I'll google for the "howland current pump". I'll just order 0.5R caddocks.
Best
Old 28th May 2012, 05:19 PM   #952
I made MyRefC, DC coupled, a couple of days ago, sounds great, thanks to everyone who took the part in development of this very nice amp.
What is the best solution to make it unity gain or close to unity (don't need much gain from it my preamp delivers a lot of gain)?
Thank you
Old 28th May 2012, 08:25 PM   #953
You can't reduce to unity gain.
Throw away your pre-amp.
Old 29th May 2012, 07:24 AM   #954
"Throw away your pre-amp."
That is easy enough, thank you .
I just realized that I asked the question, a wrong way.
What is the best value for the input pot, bearing in mind that my amp is DC coupled?
I see the values of 10k - 22k- 50k- 100k mentioned, but could not find any data DC coupled design specific. I think 100k is obvious choice but wanted to hear another opinion.
Thank you
Old 29th May 2012, 09:25 AM   #955
10k is the obvious choice. The others are options to allow poorly designed Sources to drive the vol pot.
Old 29th May 2012, 10:44 AM   #956
Thank you. R13(100k) to be taken out now ?
Old 9th June 2012, 02:05 PM   #957
Hi
After about a week of good sound and no problems at all from the first power on, my amp developed strange sibilance effect. I use audio grade parts, like PRP,Takman, Nichicon etc. Tried to increase C9 to 1000uF(C1 2.2uF/ R13 100k) and a different capmaker, but sibilance stayed.
Now, one channel does not work (relay will not click) and I killed 3pcs of LM 318 so far.
If I take out LM 318 there are no voltages on its socket pins apart from +/-12VDC(pin4 -vdc, pin7+vdc) as it should be. With 318 taken out amp will power on relay will click and there is no DC on the output. If I put LM 318 in the socket there will be various +/- voltages around 12V on all of it's pins that are used and there is ~-25VDC at the output pin of the 3886.
No smoke, no heat, at all. I made a simple circuit on the proto board and it showed me that any 318 is dead after I put it in the socket and power on the amp. I'm not sure if 3886 is dead I can't see anything wrong with the voltages its showing with 318 taken out (no DC on the output).Only thing that is strange, its mute pin is getting less than a volt. I've spent several hours staring at the board, no shorts, wrong value parts, lifted pads etc- the amp was working about 10 hours per a day, moderate power, for a week or so- hard that I misswired something. I use TF chip with HUGE HS. Any ideas? Dead 3886?
Thank you
Old 9th June 2012, 02:08 PM   #958
Could the 3886 be Fake? If it has failed, it could take out the 318.
Old 9th June 2012, 02:13 PM   #959
I doubt very much, it is from farnell or DK can't remember.
Old 9th June 2012, 02:17 PM   #960
Strange thing is that amp powerd on with 1000uF installed, I listened to it for about 15min.
to make sure if sibilance is gone or not, powerd it off to put it back in it's place switched it on but only one ch. came alive.
New guide from TI FastEddy Parts 0 19th August 2007 08:36 PM
Various questions from a diy noob regarding the myrefC. thegeek Chip Amps 8 7th June 2007 04:49 PM
Everything required to assemble MyRefC and Kookabura. Tony D. Swap Meet 3 18th January 2006 02:54 AM
what is a wave guide? Joules Multi-Way 7 12th May 2005 02:25 PM
Copyright ©1999-2013 diyAudio
