Old 10th January 2012, 03:40 PM   #931
Send a message via Yahoo to linuxguru
Originally Posted by wrankin View Post
One component in the delay circuit does differ from the value printed on the PCB and that is R21. Siva specs a 100k and the PCB (vers 1.3) lists a 220k. I haven't payed too much attention to it, but from a quick glance I would hesitate a guess that increasing R21 would increase the delay time.
Yup, there was a discussion about a year or so ago by AndrewT and BillP, among others, about the default values in the protection circuit, and the occasional failure to turn on. I found that R14=180R and R21=100k gave more reliable turn on, without loss of protection capability, than the original values, for both the Omron and Goodsky sugarcubes.
It may cause a brief turn-on/turn-off thump, but that's mostly curable either by decreasing the value of C13 or altering the power-on sequence (e.g. Source - MyRef or vice versa).
Old 11th January 2012, 09:41 AM   #932
bcmbob is offline bcmbob  United States
This subject may not be fully appropriate on this thread, but please bear with me for one more question (lots of knowledgeable folks around here for brain picking)
I have a Denon receiver that has a long mute (~2 sec) while the LED readout shows several things happening. I suspect that delay is a programmed process as opposed to simple relay and resistor design.. Does anyone have knowledge and or experience with the program/IC approach?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 5th February 2012, 05:23 PM   #933
There are so many threads about the My_RefC that it was hard to decide where to post a "FINISHED..." (As you see I decided to post it here ).
I had it running in mono-configuration a couple of weeks ago and I finally assembled the second channel yesterday (I got the kit from Siva). The amps have a DC-current of 3.5-5 mV (left channel) and 4-7 mV (right channel) - my multimeter isn't so good so the result did some "changing" while measuring. After half an hour of "slightly louder than normal" playing the LM3886 measures at 39°C and I have around 45°C in the area of the zener-diodes (is this normal?).
I still have to improve the wiring but I was eager to test the amp with the volume control and input switcher. There is nearly no hum (if muted all there is is silence ! ). I got some hum when I completely disconnected the input wires but as I said this issue will be addressed the next few days with the wiring (I guess this is the main problem). I attached some pictures of the amp running.
To say something about the sound: My Needle RS show bass and punch they never showed with my old Sony Receiver (you might see it in the pictures). I'm very pleased with the performance of the amp. As it is the first amp I assembled on my own, I think I'll have a good glass of wine after lunch .
Many thanks to Siva for the support and all of the people who invested so much time in this amp and posting their ideas/questions/answers in this forum.
Best regards
Sven
Old 5th February 2012, 10:26 PM   #934
BK - Welcome aboard. The amps just keep getting better sounding with time. Let me suggest the Mundorf power caps and siva's LFO1 as items to consider if and when you want to bump it up a bit. Even a stock MyRef though, is indeed an amazing little amp.
Bob M.
Old 6th February 2012, 05:20 PM   #935
udailey is offline udailey  United States
Passive Aggressive
Goood job Sven! Hey, dont let that big film cap get in the way of best sound. Either remove or use something better.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 6th February 2012, 06:03 PM   #936
Thanks a lot . But I enjoy listening at the moment and have some parallel projects running. So, I'm happy that it works. If I come to think about "pimping" the My_RefC I think there are so much ideas here in this forum that I'll have enough to read and to try out.
But first I want to enjoy the amp as it is and probably give it a nice enclosure.
Best regards
Sven
Old 6th February 2012, 06:06 PM   #937
Passive Aggressive
Right on. Have fun
Old 6th February 2012, 09:51 PM   #938
ClaveFremen's Avatar
Two spot-on suggestions.
I know you're enjoying your brand new My_Ref and with Siva's premium BOM you're starting from a very good point...
... but one thing, IMHO, you should consider to do before casing it.
Replace R13 with a Mundorf Zn 1.2uF 250V, you won't regret.
Or at least search on eBay a much chepear NOS Vishay MKC1862 1.5uF 63V, not as detailed and transparent as the Zn but delicious.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 7th February 2012, 05:33 AM   #939
Hello, I already asked Siva for LFO1 PCBs. Maybe I'll have some free time in the future.
All of your suggestions are welcome. I think they're the most important tuning tipps of hundreds of posts in this thread.
Thanks a lot
Old 9th April 2012, 08:59 PM   #940
Default Aikido in to MyRef
Hi
do I still need input cap(c13), my tube preamp have output cap with 10K resistor to ground.
Cheers
New guide from TI FastEddy Parts 0 19th August 2007 08:36 PM
Various questions from a diy noob regarding the myrefC. thegeek Chip Amps 8 7th June 2007 04:49 PM
Everything required to assemble MyRefC and Kookabura. Tony D. Swap Meet 3 18th January 2006 02:54 AM
what is a wave guide? Joules Multi-Way 7 12th May 2005 02:25 PM
Page generated in 0.12089 seconds (80.05% PHP - 19.95% MySQL) with 11 queries
