MyRefC build guide
MyRefC build guide
Old 3rd January 2012, 09:55 AM   #921
bcmbob is offline bcmbob  United States
wrankin,
I used the ApexJr snap-in caps successfully. The spring/curve in the leads allow both to find a point close to the edges of both holes.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 3rd January 2012, 11:38 AM   #922
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
MyRefC build guide
Originally Posted by wrankin View Post
BTW, does anyone have a good recommendation of soldering/connection methods for those two 10,000 uF caps? I was looking at getting a set of snap-in's over at ApexJr.com, but the holes are so large I was worried about how to get a good solder connection. Thoughts?
Hi Bill,
don't worry about the big snap-ins.
Holes have the right size and you'll have no problems at all soldering the caps.
Simply insert the caps (pay attention to polarity), turn the PCB mantaining it horizantal.
Put some solder on a pin of both caps so to fix them and then fill with solder all pads.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 3rd January 2012, 11:52 AM   #923
linuxguru is offline linuxguru  India
Send a message via Yahoo to linuxguru
As Bob and Dario stated, it's actually quite easy once you get the hang of it. Just flip the cap over with the snap-in leads pointing upwards. Keep track of the polarity, and place the PCB (component side downwards) over it and push the leads so that the cap is flush with the PCB. Lightly twist the cap/PCB so that the two snap-in leads are in close contact with some side-surface of the holes. Solder the contact points first, then fill in with solder.
If the snap-in leads are steel or tarnished, then it helps to clean and tin them first before insertion.
Old 3rd January 2012, 02:09 PM   #924
wrankin is offline wrankin  United States
Excellent! Thanks for all the help.
-b
Bill Rankin
Old 8th January 2012, 06:57 PM   #925
Default ...and there was music, and there was much rejoycing!
Got the caps and the LM3886's soldered in so it was finally time for some testing. Hooked up my (sacrificial) bench speaker, input from my laptop and let her rip. I had a 40W series light bulb on the powerline and it was also plugged into a kill-a-watt unit so I could check current. All the Magic Smoke stayed inside and I monitored and ran each one about 20 minutes. Things stayed nice and cool.
So now the time has come to figure out what I'm going to do about a case as well as how much heatsink I will need (esp. with a possible 4-ohm load).
Thanks to everyone for their help,
-b
Bill Rankin
Old 8th January 2012, 07:36 PM   #926
Congrats wrankin,
If you have two transformers and opt for a separate vol/pre box, dual mono-blocks are fun. Here's a couple pics of some I did and the Lightspeed passive
attenuator that controls volume and balance. A search for "heat sink" at eBay will give you many choices both designed for audio and PC CPU modable pieces.
Bob M.
Old 8th January 2012, 08:13 PM   #927
My heat sink stash.
Bob M.
Old 8th January 2012, 08:33 PM   #928
Quite a collection. I really like the idea of the monoblocks, but if I take this project in the direction that it seems to be heading - multi-amps, active crossover (probably dsp) then limiting the total number of chassis may be A Good Thing.
On the other hand, it gives you more flexibility and is really not a whole lot more work.
Certainly food for thought.
Thanks,
-bill
Bill Rankin
Old 9th January 2012, 08:49 PM   #929
Hi All, Over on the "Integrated" thread Andrew made some comments about pops and clicks when some safety devices function. That might introduce the need for an additional muting device.
Does anyone have accurate data on the length of the speaker protection mute/delay from the relay that's on the MyRef?
Bob M.
Old 10th January 2012, 03:16 PM   #930
The RevE kit from Siva that I just finished has a cut-on delay of about half a second.
From the schematic that he sent along, this looks like it's the same in his 1.4.1 RevC kits. One component in the delay circuit does differ from the value printed on the PCB and that is R21. Siva specs a 100k and the PCB (vers 1.3) lists a 220k. I haven't payed too much attention to it, but from a quick glance I would hesitate a guess that increasing R21 would increase the delay time.
I have not noticed any pops and clicks, but I have not run the boards on full line voltage yet - I always had a 40W bulb in series - and that could easily impact the start-up.
-bill
Bill Rankin
MyRefC build guideHide this!Advertise here!
New guide from TI FastEddy Parts 0 19th August 2007 08:36 PM
Various questions from a diy noob regarding the myrefC. thegeek Chip Amps 8 7th June 2007 04:49 PM
Everything required to assemble MyRefC and Kookabura. Tony D. Swap Meet 3 18th January 2006 02:54 AM
what is a wave guide? Joules Multi-Way 7 12th May 2005 02:25 PM
