MyRefC build guide
MyRefC build guide
Old 18th June 2010, 04:31 PM   #201
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
It is difficult to change the gain without unbalancing the circuit global characteristics. I wouldn't try it at all.
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 18th June 2010, 04:44 PM   #202
pengboon is offline pengboon  Singapore
My previous power amp is 12x and it allowed me to listen with vol at 12 o'clock, with very nice sensitivity of the vol. In comparison, 31 times of the MyRefC is quite a lot more for me on 96dB speakers... All the resistors seem to be in the right places. I guess I won't be messing with anything, but the sensitivity is less than ideal for my application. I'll give it a propoer listen tomorrow.
Old 18th June 2010, 04:52 PM   #203
R.I.P.
That's an extra 8dB of gain.
I would not reduce the gain of MyRefC by 8dB.
regards Andrew T.
Old 18th June 2010, 08:00 PM   #204
billo44 is offline billo44  United Kingdom
billo44's Avatar
'There won't be any room for stand offs, unless they are <0.95mm high.
I envisage a double layer of thick insulating tape to keep the soldered pins from touching the aluminium chassis floor. But, will the lid fit without buckling or crushing?'
Andrew, have you got space to mount the smoothing caps off board, lying down...
Or use a hole saw to put holes in the top of the case with the tops of the smoothing caps poking out?
Too messy for you perhaps?
Bill
Old 19th June 2010, 01:15 AM   #205
Lazarus500 is offline Lazarus500  United States
Default More cap questions:
I am still soldering away and making good progress. This is really fun. I think this one is obvious but, to verify, is C1 the unlabeled 220uf cap on the lower left hand corner of the board?
C4 and C5 came supplied with 10 mm lead spacing and the circuit board has 7.5 mm spacing. How are you dealing with that?
TIA,
rick
Old 19th June 2010, 08:39 AM   #206
R.I.P.
C9, C14, C1 & C2 are our 220uF. The unlabeled 220uF is right next to C2.
regards Andrew T.
Old 19th June 2010, 12:30 PM   #207
Stanphink is offline Stanphink  Wales
Still head down and soldering stuff on board number one of my 6 channel project - my plan being to fit the whole thing into one custom case and use 3 of these trafos - when I suddenly thought that it might not be such a good idea to have all that stuff using just one 13A IEC?
Could someone advise me about this or maybe suggest any other reasons why this is not such a good idea. I haven't ordered the trafos yet and haven't even started the case, so it's not too late to alter my plan.
Gary
Old 19th June 2010, 05:30 PM   #208
R.I.P.
where are your speakers?
Why do you need all the amps in the same chassis?
regards Andrew T.
Old 19th June 2010, 05:51 PM   #209
regiregi22's Avatar
Stanphink, IMHO, I would take the approach of making 3 stereo amps in 3 different cases. It will give you 3 times less the weight, and you will have the modularity advantage. Just pile them on top of each other for a 6 channels system.
Old 19th June 2010, 06:08 PM   #210
udailey is offline udailey  United States
Passive Aggressive
MyRefC build guide
Gary
I like the idea of all in one case because you will do less metal work and it will cost less overall.
I otherwise would prefer multiple cases. Grounding will be easier if you have a problem. Can you imagine tracing down anything in there if you have an issue on one or more channels? I mean, maybe if it was 30" wide and a foot or more deep it might be easy to work around in but otherwise, with channels stacked on top of each other or real close together it is going to be a pain later.
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
MyRefC build guideHide this!Advertise here!
New guide from TI FastEddy Parts 0 19th August 2007 08:36 PM
Various questions from a diy noob regarding the myrefC. thegeek Chip Amps 8 7th June 2007 04:49 PM
Everything required to assemble MyRefC and Kookabura. Tony D. Swap Meet 3 18th January 2006 02:54 AM
what is a wave guide? Joules Multi-Way 7 12th May 2005 02:25 PM
