MyRefC build guide
MyRefC build guide
Old 13th June 2010, 11:37 PM   #161
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
MyRefC build guide
Originally Posted by westers151 View Post
It's easy enough to shape the legs so that the resistors sit horizontally, albeit just off the board.
Something like this:
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
Old 14th June 2010, 11:31 AM   #162
westers151 is offline westers151  United Kingdom
Yep, just like that
Old 14th June 2010, 12:39 PM   #163
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
I started yesterday putting together one of the boards. I have had no problems with most of the common issues:
-I took a different approach for the resistors. I preferred to place the vertical rather than horizontal with the legs bent, so there is almost no risk of touching and adjacent component. I can see two resistor's legs too close from each other in this last Dario picture.
-I have drilled a new hole for R3 heatsink and now it doesn't touch any component. No need to trim or bend any fin. I am soldering the opamp directly to the board, so there are still around 3-4mm of clearance on top of it.
-I have soldered C21 under the board, and it left enough free space for C9 (Blackgate) to fit well. It will sit on the board and on C21 solder pads, so it doesn't vibrate of hangs on its legs. It is firmly seated.
-I placed C4 using C17 and C18 pads (not actually used), so it fits better AND doesn't touch R3 heatsink. This last one is the most relevant point, be careful with the heatsink.
-As an advice, remember to solder component's legs on both side of the board. It will provide a bigger contact surface for better electrical performance and a higher reliable mechanical performance.
-I first installed resistors, capacitors, relay and spades (all components not ESD susceptible, most of them). I will clean it thoroughly with isopropilic alcohol and a toothbrush. This will save me any troubles of frying a semiconductor because of brushing it with a plastic brush. I will solder then the LM318, LM3886, the transistors and the diodes, and leave the board with that little bit of flux. It is the best balance between having a clean board and having no risk.
So far, all audiophile components bringing any drawback have been succesfully solved.
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 14th June 2010, 01:07 PM   #164
R.I.P.
could you post a pic of the heatsink installation?
regards Andrew T.
Old 14th June 2010, 01:15 PM   #165
Reality first!
MyRefC build guide
Regi, if your approach makes you feel safer, good, but my MyRef is working since the last Group Buy... no problems at all.
Obviously with the 'orizontal bent' approach some care is needed.
Dario
Old 14th June 2010, 01:21 PM   #166
regiregi22's Avatar
As soon as I get home
Old 14th June 2010, 01:23 PM   #167
regiregi22's Avatar
Of course, your choice is good and will work alright. Just a matter of personal choice
Old 14th June 2010, 03:30 PM   #168
madisonears is offline madisonears  United States
Regi and other builders,
Be careful with Blackgate C9 if C21 is under the board. I found this arrangement fits the best, but be certain that the C9 leads are not touching C21 pads. I put a thin piece of foam under the Blackgate, which insulates it from C21 pads and any other accidental contact, and provides some reduction of vibration as well.
Perform a thorough visual inspection of all leads, especially those bent resistors, before applying power.
Peace,
Tom E
Old 14th June 2010, 05:43 PM   #169
vlad712 is offline vlad712  Moldova
vlad712's Avatar
Thank You Regi for the good starting point for the novice
Old 14th June 2010, 09:38 PM   #170
regiregi22's Avatar
Peace,
Tom E
Thank you for the advice. I can clearly see that both pads stay away near 10mm away from each other, so I am safe
I was worried about it staying hanging, but when I bended the legs and soldered it to the board, it was kept quite firm, you can't move it. But it is easier and more practical to use somethink like your pads.
MyRefC build guideHide this!Advertise here!
New guide from TI FastEddy Parts 0 19th August 2007 08:36 PM
Various questions from a diy noob regarding the myrefC. thegeek Chip Amps 8 7th June 2007 04:49 PM
Everything required to assemble MyRefC and Kookabura. Tony D. Swap Meet 3 18th January 2006 02:54 AM
what is a wave guide? Joules Multi-Way 7 12th May 2005 02:25 PM
