| Chip Amps Amplifiers based on integrated circuits |
#131 | |
Passive Aggressive
So from what you have said we can probably rule out a dead LM318 but we can rule IN that the proper LM318 will do the trick. I honestly wonder if the silkscreened one is a real Nat Semi chip. I know I sent it to you but obviously I am not in the fake IC business and obviously you have two supposedly Nat Semi ICs of which only one works. Your other 5 that DONT work: Where did you get them from and do they look like the silkscreened one? From what I remember from the previous buy and from earlier posts in the original thread a lot of people have had clicking trouble. I wonder if your home voltage is lower than normal and if for some reason its fine for the one IC and right there on the line of fine/not fine for the other ICs. Troy I think you have helped a few people with this. Wasnt there a resistor that folks lowered the value of when they had the clicking trouble? The sink is just way to small and the sinks on your Caddocks are going to let your Caddocks fry. This is basically a non starter. If you leave in those heatsinks they will fry if they have not already. Both the LM3886 and the Caddock but the Caddock first. I also wonder where is the 470k resistor near the opamp on the left side. Maybe you mounted it below.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#132 |
Passive Aggressive
Forget my 470k remark. I saw your answer.
REGI, with the LDRs facing away from you the trimmer on the LEFT should be a 5k. Use the 5k pot here. 200r will still allow the board to work but you wont have balance control. 200R only belongs on the right hand side and it will allow balance control there for balancing minimum resistance of the shunt LDRs but will not effect the max resistance. The 5k has a large effect on the max resistance of the series so therefore you can have balance control. Uriah
#133 |
Passive Aggressive
The ceramic caps in my hand have 100, 220, 221 on them. Two of them say K2J. I think that we have here 10pf, 22pf, 220pf. The 100 means 10 with zero zeros after it. So 10pf. 220 means 22 with zero zeros after it so 22pf. 221 means 22 with one zero after it so 220pf.
Uriah
#134 |
Any idea what the K2 represents?
#135 |
Passive Aggressive
Something to do with Kemet.
#136 | |
Could K2 be, like uriah proposes, some code for identifying it as a Kemet device?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN! |
#137 |
Passive Aggressive
Kemet, 200V, 5% = K2J
#138 | |
Passive Aggressive
That last statement goes for the series LDRs. I prefer the Shunt to be balanced at min setting with the trimmer and DMM. After that I use my ear with the 5k. Uriah
#139 |
#140 |
| New guide from TI | FastEddy | Parts | 0 | 19th August 2007 08:36 PM |
| Various questions from a diy noob regarding the myrefC. | thegeek | Chip Amps | 8 | 7th June 2007 04:49 PM |
| Everything required to assemble MyRefC and Kookabura. | Tony D. | Swap Meet | 3 | 18th January 2006 02:54 AM |
| what is a wave guide? | Joules | Multi-Way | 7 | 12th May 2005 02:25 PM |
